Couple of questions
I should probably post on a Charger forum, but hey.. you guys know me plus and I can ask dumb questions and use run on sentences with no grammar what so ever and some how yous understand me...
ok today's subject is the Dodge Charger,
First question is the bulkhead has a couple mystery wires(pictured) I think its for a wiper(at least what I can make from the wiring diagrams) however..the wiper is hooked up and working fine, looks like someone chopped into it at once time or another..any ideas what they are..I want to start cleaning up the engine bay(top row two wires at the right)
5824&d=1427942881 [/IMG]
5825&d=1427942946 [/IMG]
next, I hooked up the tti exhaust, leaks worse then a submarine with screen doors. I need to know what everyone else uses with these headers (too long of a bolt wont work they hit the tube in some places) I tried the percy gaskets ..sounds like a friggin helicopter is landing on the roof
also tail pipes don't fit out of the box..(thought they might ha) is this anyone else experience?
5826&d=1427943463[/IMG]
5827&d=1427943465[/IMG]
and finally, I just (sloppily) ran the trans lines, anything neat and tidy I can using other then wire ties I got to figure out how to get them out of the way from the steering linkage and headers (everything is in the way with these headers....next time..manifolds)
5829&d=1427943927[/IMG]
5828&d=1427943863[/IMG]
Piper Wrote:next, I hooked up the tti exhaust, leaks worse then a submarine with screen doors. I need to know what everyone else uses with these headers (too long of a bolt wont work they hit the tube in some places) I tried the percy gaskets ..sounds like a friggin helicopter is landing on the roof
Hard to tell from the picture which bolt it is, but sometimes with headers you have to back the header away from the flange, insert the bolt and then tighten the bolt so the header and bolt meet the head together. I use studs on the outside bolt holes to support the header while doing this.
you are right a lot of sliding back and forth, I like the stud idea!
Wire connector could be for hood mounted turn signal indicators
I ran my trans cooler lines along the left frame rail down to the torsion bar crossmember then over the header collector and back forward to the trans fittings - works good. I also wrapped insulation around the hoses where they go over the exhaust.
On those header leaks - make sure the bolts arent too long and bottoming out before actually tightening the flange.
thanks for the input! I see they make a heat sleeve that will slip over the hoses, also mystery solved those wires are for the air conditioning
Andy and I would like to know what transmission cooling lines are for?Rofl
  Couple more upgrades Piper 5 3,571 04-20-19, 06:56 AM
  Engine and transmission questions odot365 14 9,158 08-21-16, 09:21 PM
  2 questions OldSkool 3 3,407 04-24-16, 04:14 PM
  Some more 68 Coronet Questions slimert 6 5,083 04-15-15, 01:16 PM
  Just a couple of pics before she goes away for the winter Warhawkfight34 8 4,567 11-14-14, 04:49 PM
Last Post: harold prentice
  440 Motor Questions... Jeff Bailey 5 3,477 08-18-14, 11:13 PM
Last Post: Drag-Net
  A couple of more things I finished Warhawkfight34 5 4,066 03-27-14, 11:43 AM
  A couple of pics mike1968rt 7 4,746 03-26-14, 12:24 AM
  67 coronet with 273 engine have questions!!! uncledon 7 4,626 02-27-14, 04:29 PM
