Threads: 19
I've just had my instruments out and reconditioned. The good news is the speedo now works, but the fuel gauge has stopped!
What are the most common causes of this? Thanks
Threads: 482
Sending unit grounded?
If you have a manual they show how to test gauge
Threads: 19
12-06-14, 07:28 PM
(This post was last modified: 12-06-14, 07:46 PM by NZ 68 R/T.)
Thanks 67r/t. I'll look at that. I was thinking that as it worked prior to the instruments being removed that it must be at the dash end?
Any other logical reason??
Can you read wiring diagrams?
If so locate the sending unit wire at the kick panel and ground it out to see if the gauge and harness in the front works.
It's a quick way to split the system in half and go in the right direction.
BTW, that idea wasn't mine, it came from some one here.
Threads: 58
Blue wire behind kick panel. Unplug and ground blue wire with key "on" gauge should peg to full!
If it does not move? Then the sender has issues. does temp gauge work? If that's not working either? Then the voltage limiter has failed.
Threads: 58
Opps:
If it pegs grounded? Gauge is okay. You have a "open" wire from sending unit. That you can also check from the plug behind the kick panel. Measure ohms blue wire to ground. If you get a .0 reading? The sender is bad or the wire came off the sending unit.
also to note if the temp gauge is working? The fuel gauge and temp gauge use a voltage limiter to bring volts to about 5 volts. If the limiter failed? Neither fuel and temp will work. So? There's 3 things it could be, or a combo of one or more.
Testing is cheap and easy.
I bought a new mother board from classic industries. And it has the modern solid state limiter built into it.
It cured both my fuel and temp gauge issued.
Threads: 19
Can anyone tell me what the part no is for a new mother board for a 68 R/T with the standard gauges. Does this include the voltage limiter? Thanks
