Head question
Dug the new motor out from under the bench and got it on the stand.. From what I can see, the heads were milled a bit. Any way to tell how much without pulling the heads off?
I'm fairly sure not, but before I go tearing it down to check head volume, figured I'd see if there was some old school trick to checking.
Did you find a way of checking with heads on ?
No.. the only place I could reference was a intake bolt hole to a straight edge on the underside of the head. I compared that to 4 other sets of heads I have, but since I don't know if they were cut in the past, there was no true reference to go by.. Since the motor is on the stand I just pulled em off and will CC em..
  Lower control arm question Piper 2 19 10-17-23, 01:57 PM
  Question theman440 23 2,984 06-02-22, 01:39 PM
Last Post: tgranthamfd
  Distributor question 67RTBlue 9 6,884 01-09-16, 11:13 AM
Last Post: 1badstroker
  Brake line question-passenger side line hump or no hump? 67RTBlue 2 2,934 01-07-16, 11:12 PM
  67 Coronet power window question Lipers1 8 5,324 10-11-15, 01:47 AM
  New owner - Choke question/FM Converter tuckerboynton 6 4,782 07-12-15, 05:09 PM
Last Post: Redneck
