Front Wheels Locked
Hello All,
I have been tooling around town with my 69 Coronet 2 door hardtop.....freshly rebuilt differential and new axle bearings and seals....
I noticed that the car didn't seem to coast to a stop at intersections....instead, it appeared to slow down without braking....it appeared a brake was dragging....
I jacked car up, and neither front wheel would rotate....I bled the passenger side wheel cylinder and both now turn freely....
I have a rebuilt master cylinder, all new lines (SS and rubber), and all new wheel cylinders.....
when rebuilding the system, I had to extend the booster plunger in order to get fluid to the rear of the car....and I have driven it before and didn't notice this happening....
any thoughts on the cause?
thanks,
Mark
brakes not adjusted properly or self adjusters not set up/working properly.
Make sure you still have slight play in pedal so brakes aren't dragging when not applied.
If you open front bleeder and it released brake then back track from there.
X2 the problem is in the hydraulics because you made the problem go away by letting out some pressure.
I agree with going after the booster push rod first. You can fix that easily with out removing or bleeding. Use something like a small screw driver to compare the push rod length to the recessed hole in the piston.
Also remember, new doesn't mean good...
I had the same problem when the front tires would lock up when the car warmed up. It was because I had a original drum master cylinder temporarily until I got the disk/drum master cylinder after I converted the front brakes to disk.
Hey all,
I shortened the plunger on the brake booster.....I checked brakes....all good....
I drove the car over 100 miles yesterday and this morning.....no issues....I thought I had this licked....
when my son took it out this afternoon, the brakes were again locked.....
any thoughts now?
I don't know how you can make the brakes get locked again, but wait for it to happen, then loosen the line at the master cylinder to see if you still have residual pressure. You need to know what is holding the pressure in.
It could still be more adjustment on the booster, it also could be a stuck master cylinder, or collapsed hose.
Hey all,
thanks for the replies...
would a collapsed hose have any outward signs that it's collapsed?
if it's the plunger length, how come it takes so long for this condition to develop?
also, what is the purpose of the vacuum hose on the booster? could this be an issue?
thanks,
Mark
Ditto on the collapsed hose, externally it will look O .K. over time inside material can turn to mush and cause brake to hold although it seems odd for both to lock, are you sure they both are hot?
Hey all
i drove the car 40 miles or so and everything worked fine until I went
to pull the car in the parking space at a restaraunt
the car would barely move and all 4 wheels drums were hot
I am thinking I need to shorten the booster rod a bit as
once the fluid heats up there is no wY for it to get back to the master
any other thoughts?
  68 Bee-bleeder screws on front brakes rlsbee 3 3,500 05-06-16, 02:50 PM
  1967 coronet fiberglass front bumper Stage III 0 2,654 06-09-15, 07:43 PM
Last Post: Stage III
  front window 1967 dodge coronet 440 Markfive 3 3,989 09-16-14, 11:32 AM
  I have front disc brakes on my 67 coronet 500....is that factory? how do i tell? uncledon 27 15,706 06-02-14, 11:13 AM
  Front ride height adjustment Hibbing_Coronet_500 4 4,521 04-28-14, 05:34 PM
  TIRES FOR MAGNUM 500 WHEELS harold prentice 6 7,482 03-16-14, 12:42 PM
Last Post: harold prentice
  66 to 67 front end kildump 3 4,369 06-13-13, 10:50 AM
  66 Front Window Question stamm321 2 3,577 05-07-13, 01:12 AM
Last Post: stamm321
  1967 Coronet front bumper turn indicators Hibbing_Coronet_500 10 7,762 05-06-13, 09:36 PM
