need some guidance
i bought her :] she came with a little good things like a electric fuel pump pirelli tires and many more im so happy i bought her i have 2x the switches now floorpan :]
149714981499
Nice score Manny
Way to go!
the ac still has pressure in it push the little valve and air came out :] O_0 cant wait! is there a guide how to take off windows?
nice score! I like it ... post more pics when you can!
Congrats Manny. On taking the windows out, usually you have to sacrifice something. Either the glass or gasket. So if you are trying to save the glass, I'd suggest you carefully remove the trim, cut the gasket from the top to expose the windshield edge completely, then VERY carefully separate the glass from the inside part of the gasket. This is where most people crack perfectly good glass. You can't flex the glass at all, it will crack very easily. You use either a putty knife or utility knife and take your time. When the glass is ready to come out, it should not be stuck anywhere. Also make sure you don't pry on the glass when taking the trim off.
Good luck. That car looks like a great parts car. Try not to let anything go to waste, when you are done with it, sell it to someone else.
Well, I hate to be the bearer of bad news to Manny and others who were looking to use the front windshield and it's related gasket and exterior trim moulding parts from a 1969 Coronet 4 door sedan on their 1969 Coronet 2 door hardtop, or 2 door sedan, because as Rich has already mentioned (and very clearly to me at least Smile ), none of those various parts are interchangeable between the 2 and 4 door body styles.
Below are the 1969 factory part numbers for all of these parts and the specific body style applications those parts fit. The part numbers for the front windshield glass and front windshield gaskets are used on both the 1969 Dodge and Plymouth B-Body cars, but for the front windshield exterior trim mouldings, upper, lower and side, I've only included the part numbers for all of the 1969 Coronet models due to the time it would take me to list all of the Dodge and Plymouth B-Body part numbers for that trim moulding.
As mentioned, this information comes from the 1969 Chrysler factory parts book along with some additional minor editing and formatting by me to make the information easier to read.
I hope this helps you out Manny and any others considering this same swap. I hate to keep harping on this same thought, but a copy of a factory parts book which is available as a FREE download on the MyMopar web site that I help out on for most vehicles from the 1950's up to 1973, along with a factory service manual that you can purchase in either a CD, or printed book format for your specific car, will be your two very best friends during any type of restoration work you are planning on doing to your car. Wink
After typing all of the information below, I'm gonna go listen to some Rammstein music to get the feeling back in my fingers and hands!!! Rofl
FRONT WINDSHIELD - GLASS
R = Plymouth B-Body models
W = Dodge B-Body models
Part number: 2811265
Parts book section number: 23-66-135
Part description: Glass, front windshield, R, W, models, clear
Part application: 2 door sedan, 2 door hardtop, fastback
Part number: 2811266
Part description: Glass, front windshield, R, W, models, tinted
Part number: 2570605
Part application: convertible coupe
Part number: 2570606
Part number: 2570295
Part application: 4 door sedan, 6 passenger station wagon, 9 passenger station wagon
Part number: 2570598
FRONT WINDSHIELD GLASS - GASKET
Part number: 2811263
Parts book section number: 23-66-235
Part number: 2842790
Part number: 2861217
FRONT WINDSHIELD GLASS - EXTERIOR TRIM MOULDIN - UPPER SECTION - 1969 CORONET MODELS ONLY
W-L code = Low price class, Coronet Deluxe trim level models
W-M code = Medium price class, Coronet Super Bee trim level models
W-H code = High price class, Coronet 440 trim level vehicles
W-P code = Premium price class, Coronet 500 trim level models
W-S code = Special price class, Coronet R/T trim level models
Part number: 2811259
Parts book section number: 23-23-65 / specific exterior trim illustration pages for each model
Part description: Moulding, windshield, outside, upper
Part application:
Coronet Deluxe, W-L, 2 door sedan
Coronet Super Bee, W-M, 2 door sedan
Coronet Super Bee, W-M, 2 door hardtop
Coronet 440, W-H, 2 door sedan
Coronet 440, W-H, 2 door hardtop
Coronet 500, W-P, 2 door hardtop
Coronet R/T, W-S, 2 door hardtop
Part number: 2584699
Part description: Moulding package, windshield, outside, upper
Part application:
Coronet Deluxe, W-L, 4 door sedan
Coronet Deluxe, W-L, station wagon
Coronet 440, W-H, 4 door sedan
Coronet 440, W-H, station wagon
Coronet 500, W-P, 4 door sedan
Coronet 500, W-P, station wagon
Part number: 2586272 and 2586273
Part application:
Coronet 500, W-P, convertible coupe
Coronet R/T, W-S, convertible coupe
FRONT WINDSHIELD GLASS - EXTERIOR TRIM MOULDING - LOWER SECTIONS - 1969 CORONET MODELS ONLY
Part number: 2811888 and 2811889
Part description: Moulding, windshield, outside, finish lower
Part application:
Part number: 2585852 and 2585853
Part description: Moulding package, windshield, outside, lower
Part application:
FRONT WINDSHIELD GLASS - EXTERIOR TRIM MOULDING - SIDE SECTIONS - 1969 CORONET MODELS ONLY
Part number: 2811260 and 2811261
Part description: Moulding, windshield, outside, finish, side
Part application:
Part number: 2585850 and 2585851
Part description: Moulding package, windshield, outside, finish, side
Part application:
Part number: 2586274 and 2586275
Part description: Moulding package, windshield, outside, side
Part application:
All good news for you on the floor pans though Manny. As Mike and others have said, all 1969 Dodge and Plymouth B-Body cars use the same front floor pan assembly and all except the station wagon models use the same center and rear floor pan assembly, so the 4 door sedan that you purchased will help you with your 2 door hardtop there.
FLOOR PANS - FRONT FLOOR SECTION
Part number: 2900060
Parts book section number: 23-32-22
Part description: Pan, front floor (one piece unit for drivers and passenger side)
Application:
2 door sedan, R, W, all
2 door hardtop, R, W, all
convertible coupe, R, W, all
4 door sedan, R, W, all
6 passenger station wagon, R, W, all
9 passenger station wagon, R, W, all
FLOOR PANS - CENTER FLOOR SECTION
Part number: 2900801
Parts book section number: 23-32-24
Part description: Pan, center floor (one piece unit)
Application:
convertible, coupe, R, W, all
Part number: 2894517
Part description: Pan, center floor, with nut (one piece unit)
Application:
FLOOR PANS - REAR FLOOR SECTION
Part number: 2838707
Parts book section number: 23-32-48
Application:
4 door sedan
Part number: 2860810
Part description: Pan, rear floor, front
Application:
Part number: 2895348
Part description: Pan, rear floor, rear
Application:
thats a whole list thank you! but was wondering on removing my 2door model going to get ready to start cutting things up :] and painting it
  Need Some guidance Manny951 4 4,159 12-12-13, 11:55 AM
