Threads: 482
01-24-26, 08:08 PM
(This post was last modified: 01-24-26, 08:11 PM by 67r/t4speeder.)
(01-24-26, 03:30 PM)67440Dodge Wrote: Where are the ceramic plug ends?
Remember Max is slow?
Amazing how long this original wire last.
Everyone I take out is done but still working fine.
new terminals
Threads: 482
Anyone seen crimpless plug wires before? Dated 1990.
My last set were already assembled for a big block.
Threads: 68
I used to work at a Chevron station way back. You could buy one spark plug wire, they offered a few different lengths, the spark plug end was assembled but you could cut to them to length, for the cap end you got a boot and a bent wire for a terminal. It pushed straight into the end of the wire and bent around the side and poked into the side of the wire to secure it. I believe the parts were branded as ATLAS.
Threads: 482
(01-28-26, 09:14 PM)theman440 Wrote: I used to work at a Chevron station way back. You could buy one spark plug wire, they offered a few different lengths, the spark plug end was assembled but you could cut to them to length, for the cap end you got a boot and a bent wire for a terminal. It pushed straight into the end of the wire and bent around the side and poked into the side of the wire to secure it. I believe the parts were branded as ATLAS.
Yes I remember those too, I worked at Phillips 66.
Threads: 312
Same here at the Exxon station I got my first job at. Had a huge shelf in back filled with every ignition part you'd need..
Threads: 482
Good memories
Threads: 68
Three oil companies represented, here. Thats cool.
