54 Coronet Build
Welcome back 54, looks like you are well on your way.
Worked on car a little... Picked up a steering box and linkage from a 67 mercury comet. It looked like it would work for me. I can't use my stock steering box due to clearance with the starter. Mocked it up and looks like it might just work without much work! WOW What do you think? Will it work? Seems to good to be true...
1280
1281
1282
1283
1284
Looks like it fits nicely but how about exhaust manifold clearance?
The exhaust manifold should not be a problem as long as I get a exhaust mainfold that dumps downward at the rear... Which is ok because I was planning on rnning a stock stlye manifold anyway. I will also be shorting the steering shaft a little to connect a universal joint to my stock steering column. So I should be ok. I'll keep you posted!Smile
Well I've been working and not posting... I removed motor and trans (trans will get rebuilt before I put it back in) to work on steering. Here's some pics of my progress... Smile
Original steering holes
1586
1628
Made slugs and welded in
1629
1587
Location holes for new steering box
1630
1588
Drilled 5/8 holes to insert round pipe for strength
1631
1589
Weled them in...
1632
1590
Grinded them smooth and possible
1633
1591
Mounted steering box
1634
For some reason I'm having problems with my pics. It also will not let me post another other pic of other side of gearbox... But you get the point if you can see these picsWink
1592
1593
Couple more things to do on steering. Need to cut and isolator pad for behind gear box and add lock nuts. Also need to mount drag link and re-paint rail. I'll keep you posted!! I think it came out ok, What do you think
You have been busy with that list.
Pics wont open for me though Sad
Please let me know if the pics are working now
Working good now thanks, now I go check them out thanks
Looks nice.
Here are some more pics to see what I have been up too...
Got transmission rebuilt and installed...
Picked up a steering column from speedway.
2639
Did some minor things to it to make it work.
2640
I able to use my stock turn signal!!
2641
Just need to make a clean connection...
2642
  Rear axle replacement for '58 dodge coronet acer 3 20 06-06-24, 02:15 PM
  '58 Coronet Windshield Wipers acer 1 29,589 06-09-20, 03:41 PM
  1956 Dodge Coronet Parts for Sale higbull 0 29,969 07-20-18, 03:14 PM
Last Post: higbull
  1/18 scale Coronet Club Coupe Jim 68cuda 0 12,244 06-09-17, 04:20 PM
Last Post: Jim 68cuda
  Wiring: Accessibility at 1950 coronet crnet50s 1 13,757 01-03-17, 10:36 PM
  50 coronet wont start 50net 18 21,343 09-27-15, 08:46 PM
Last Post: 50net
  1958 Coronet Wheel offset? samdjr74 0 3,956 08-04-15, 11:49 AM
Last Post: samdjr74
  50 Dodge coronet sierra steel woody wagon johnson3900 4 5,834 09-01-14, 11:17 PM
  "50" odd banana coronet 50net 0 4,322 01-05-14, 04:01 PM
Last Post: 50net
  Need help keeping the Throttle Level attached to the Throttle Body, On a 1952 Dodge Coronet 52-Coronet 1 4,149 10-11-13, 07:06 PM
Last Post: 48mirage
