"50" odd banana coronet
does someone have the book where you can find where & when your car was made? when I purchased my car first thing I did was change trunk lock.was a "late dodge" lock ,so here im thinking I have a "later made" 50 model,then I bought a antenna to fill hole on "passenger" side fender,when I noticed all other 50 model are on drivers side,but noticed the meadowbrooks have on right side.now im trying to find replacement hinges for hood,after hitting wall after sending pictures out,i discovered by viewing plenty of youtube shots of engine bays ,that my 1950 coronet,actually has the bracket set up for a 1949.so is it mixed breed or what? so hoping look up may help for ordering parts. does anyone have same situation?{ yes title says 1950 coronet also grille,interior.etc states its a coronet} update also order tune up parts ,when went to install found out not same.distributor is a1951style
  Rear axle replacement for '58 dodge coronet acer 3 19 06-06-24, 02:15 PM
  '58 Coronet Windshield Wipers acer 1 29,589 06-09-20, 03:41 PM
  1956 Dodge Coronet Parts for Sale higbull 0 29,969 07-20-18, 03:14 PM
Last Post: higbull
  1/18 scale Coronet Club Coupe Jim 68cuda 0 12,244 06-09-17, 04:20 PM
Last Post: Jim 68cuda
  Wiring: Accessibility at 1950 coronet crnet50s 1 13,757 01-03-17, 10:36 PM
  50 coronet wont start 50net 18 21,343 09-27-15, 08:46 PM
Last Post: 50net
  1958 Coronet Wheel offset? samdjr74 0 3,956 08-04-15, 11:49 AM
Last Post: samdjr74
  54 Coronet Build 1954 in progress 45 24,224 03-27-15, 12:00 AM
  50 Dodge coronet sierra steel woody wagon johnson3900 4 5,834 09-01-14, 11:17 PM
  Need help keeping the Throttle Level attached to the Throttle Body, On a 1952 Dodge Coronet 52-Coronet 1 4,149 10-11-13, 07:06 PM
Last Post: 48mirage
