Hemi build
you going EFI? Thought you were doing carb.
Yes going EFI. going carb and non OD trans would seem dumb. Getting a carb intake is nearly impossible unless you want a single plane which are meant for EFI anyway.
Sweet... using the Dak's fuel pump or going with something else?
That’s something I have researched a little bit. I believe magnum and hemi have different pressures for the injectors. Holley sells a bolt in pump for a ridiculous price of about $450
Check Tanks Inc. They may have a tank/pump combo already setup for that.. Just need a external regulator to drop it to whatever the 5.7 wants
Nothing for Dakotas on their site
If the Dakota was a TBI setup then it's definetely lower. Give the guys at Tanks Inc a call and see if they got anything that will work.
I had to use one of their weld in recesses and a in tank pump on my car cause they didn't make them for 66/7 yet. (Not sure if you got plastic tank or not, might be an option).
It’s a 96 so it wasn’t TBI, was a 3.9 and plastic tank. I’ll call them when the time comes. Thanks!
  5.7 hemi build 65rbdodge 28 116 01-22-25, 09:39 PM
  Build Numbers stonehengeheel 5 810 11-10-22, 08:52 PM
  1967 Coronet Hemi Value strangleholdracn 7 1,574 04-02-22, 08:03 PM
  Race Car new motor build has begun......... markz 14 28,593 02-22-20, 12:11 AM
  J Leno rolls over Hemi under glass crlush 3 4,437 05-21-16, 10:10 AM
  Quick story about HEMI'S Warhawkfight34 18 8,951 02-17-16, 08:41 PM
Last Post: 1969 Hemi RTs
  I'm so excited! My GTX Build............... markz 8 4,842 01-16-16, 01:05 PM
  1966 Hemi Coronet Survivor mozz at rpm 17 8,966 01-02-16, 06:24 PM
Last Post: Irores
  Getting Excited - GTX build markz 8 5,393 07-02-15, 03:05 PM
Last Post: Joe mama
  Hard life Hemi 67r/t4speeder 4 4,295 04-20-15, 06:50 PM
