1965 Coronet 4 speed lubrication confusion
Krooser Wrote:I worked for Mopar dealers from '68-'72... Type A/B/Dexron was the factory fill.
Interesting
definetely easier to find than GL-4 oil these days..
Last time I bought Sta-Lube I had to drive 45 minutes to a Napa that actually had it in stock. one that was half hour away that showed it in stock called me when I ordered online and said the website was wrong, they were out and weren't ordering any more.
If atf scares you use GM Syncromesh fluid...about a 50wt gear lube
(09-16-19, 01:47 PM)finz68 Wrote: When I first purchased my Coronet, the shop that I used to flush and replace all fluids put Dextron 3 into the gearbox saying that was the required lubricant after research.  I am planning on taking the car on a fairly long trip soon and am uptight that it doesn't have 90w gear oil.  Should I be?  Thank you!
  Did you decide on which way to go? How did your trip go if you went yet?
   I and others are interested.
Just take note that GL5 does not play well with yellow metals like ssyncros... GL 4 is OK but I would still use atf.
Gear lube 7s designed to absorb shock loads that you don't see in constant mesh transmissions.
  67 coronet window fuzzies D1esel 2 15 03-24-25, 09:07 AM
Last Post: D1esel
  Speaker confusion Kingspagetti 5 1,954 10-28-23, 09:32 AM
Last Post: Histoy
Last Post: revel68
  4 speed crank mike1968rt 5 10,717 10-24-18, 06:27 PM
Last Post: dag1969
Last Post: Just Wheels
Last Post: wafo63
