Hi all from the Netherlands 69 Coronet R/T owner
Hi all,
New here.
Recently owner of a 1969 Coronet R/T, Sublime green with a 440 HP engine and 727 auto tranny.
Signed in here to read some more info and help and hopefully provide some as well with my knowledge gained so far.
The cars registration shows it has been sold new here in the Netherlands in 1970, although the current VIN # of the car that has been stamped in the chassis (required to be stamped here) does not match the cars data and is a false registration which happened a lot with these cars years ago.
Most likely it got another Coronet registration and they illegally transfferred the VIN and licence plates.
The car was bought in the understanding to be not a matching #'s which i and the seller realized.
After spending some time on the car and reading about matching numbers i decided to at least check to find some digits and found that the full VIN was stamped on the engine, matching everything on the car, and found the same last 8 digits in the radiator support and below the trunk lid rubber seal.
VIN as per registration: WP23G0A******, VIN found on the engine and chassis: WS23L9E******
All in all a good buy i guess, the only thing not being original is most likely the paint color, as far is i know this color was introduced in 1970.
But as they car must have been imported at some point i am hoping to find on this forum a previous owner or documentation of the car from it's time in the US.
10902]10903]10904]
See you around!
Wietse
Wow, very nice Wietse. Hoping to get one by the end of thawed myself. Im in negotiations now.
Thanks.
Good luck with the negotiations.
Dunno if you are hunting for a number matching car but just make sure you do your home work first! 👍
I was really lucky with this. (Dumb luck) 😁
Welcome Wietse
Welcome!!
Welcome. What is the VIN on the dash? Or is it still there?
The dash tag is gone, same as the fender tag.
The only numbers i have are a hand stamped VIN (which is from another car) and the matching VIN on the engine, radiator frame and trunk lid lip.
  1965 Dodge Coronet 500 Mygirlditto 2 9 05-22-25, 11:38 AM
  1969 Coronet 500 Convertible 31ctg 47 27,444 03-22-23, 06:22 PM
  Need advice to keep my '65 Coronet 440 alive. pistolero5150 1 24,867 11-20-19, 05:29 AM
Last Post: MarkMopar
  1965 CORONET 500 4 SPEED CONVERTIBLE finz68 6 25,520 09-11-19, 02:28 PM
Last Post: finz68
  I'm a Coronet Virgin! 493mike 7 22,197 07-26-18, 08:16 PM
Last Post: beefman
  New Member with 65 Coronet 500 project for sale 65coronet500 0 15,667 01-10-18, 02:07 AM
Last Post: 65coronet500
  New coronet owner Brett006 4 17,952 07-11-17, 02:51 PM
Last Post: RT K_line
  multi coronet owner leroy 4 4,836 04-28-17, 09:46 PM
  New Guy - 70 Coronet 500 jpock76 17 11,495 02-11-17, 09:08 PM
Last Post: Robb
  Newbie Question - 1966 Dodge Coronet 500 - drum to disc conversion Craig5498 11 8,211 01-04-17, 02:59 AM
Last Post: Craig5498
