Fuel gauge
I have steel line from tank to carburetor .i believe mine should be ground from steel tank to body thru straps
Custom has the idea, it clips only on the metal parts though and rubber flex hose in middle. Making a solid ground connection from pick up tube to fuel line going to carburettor.
Custom66coronet Wrote:Yes it connects the fuel line to line coming out of the tank. over the piece of connector rubber hose. and provides the ground for the fuel gauge.
X2!
Here is the ground strap on my 69's fuel line.
Guess 49 and up it changed.my outlet is at bottom edge of tank.no rubber hoses.and at sender just one wire at top.its a 1950
Is the tank touching clean metal? Mabey it's loosing the ground circuit inside the tank.
Yes tank secured tightly to trunk with straps.even temp.ran a grd wire from top of sender to body.still have to trace out wiring under dash.developed another project bleeding brakes line near engine bay started leaking, so that will be next ,changing brake lines
  Original fuel line 50 dodge 50net 3 17,832 04-03-17, 01:06 PM
  1954 DODGE ROYAL FUEL TANK SENDING UNIT... PART NUMBER ? onebad54 10 18,318 05-05-16, 12:49 PM
Last Post: onebad54
  fuel tank plug 50net 2 5,442 05-03-14, 10:16 PM
Last Post: 50net
