Back up lights
Hi everyone. I was hoping to get some direction with my inop back up lights. When I put it in reverse they flash but that's it. Is there a switch with an adjustment in the shifter mechanism or do you think it's just a bum n/s switch?
From memory when I put ours together the switch mounted on the shifter under the console is adjustable. A sloppy shifter linkage will make this tricky. I adjusted ours to the center of the "slop". Put the car in reverse and have someone watch the lamps as you adjust it. Might try cleaning the switch with electronics spray cleaner too.
Ok will do thanks Blue.
That did the trick, thanks!
Cool man!
  Dial back timing lights 67440Dodge 3 1,771 08-08-21, 09:25 PM
  I'm back! 67440Dodge 22 25,548 03-13-21, 01:10 AM
  Bring paint back (even if temporary) Piper 28 26,295 07-16-19, 05:50 PM
  back after a long time rp23g7 14 7,582 12-20-17, 03:47 PM
Last Post: rp23g7
  Timing lights-Innova 5568? 67RTBlue 2 3,560 10-16-16, 03:01 PM
  Dash lights tgranthamfd 13 8,526 08-25-14, 04:34 AM
Last Post: tgranthamfd
  Changed my dash lights to LED! 67 Coronet 500. TekHousE 9 7,352 08-16-14, 12:32 AM
  Back to square one. Warhawkfight34 6 3,837 08-14-14, 10:30 AM
  want to put factory radio back in my car uncledon 23 10,258 05-29-14, 06:51 AM
Last Post: mrconvertible
  bee marker lights David Hunt 1 2,698 04-17-14, 08:39 PM
Last Post: Drag-Net
