Heater control cables-routing question
When installing the dash one of the cables (temp control) that comes off the controls rubs on the wiper linkage arm under the dash. I currently have it routed under the arm. The angle at which it comes off the controls on the dash its pushing it up onto the arm. I'm wondering if it is supposed to go above the linkage which might allow it to not rub the way it does now? Can anyone look up under the dash and see theirs?
The cable with the red band in the pic.8547]
There supposed to be a clip that holds it down on the top of the heater box. Can you sneak a tie wrap on it, or are you going for original?
ws27 Wrote:There supposed to be a clip that holds it down on the top of the heater box. Can you sneak a tie wrap on it, or are you going for original?
This is the control that lays on top of the box not on the front. I know the clip thing that is riveted to the heater box I have. I popped the linkage off and dropped it below the cable and it seems right like this and no longer rubs on the cable.
Looked at both of my cars and both cables are on top and cables rub linkage barely
I popped the wiper linkage and its better that way. Just didn't think the cable would route "through" the linkage assy.
  Lower control arm question Piper 2 19 10-17-23, 01:57 PM
  Question theman440 23 2,984 06-02-22, 01:39 PM
  Vin # decode and emblem question. Rcrail 4 3,997 03-07-20, 03:38 AM
  Why do the heater hoses keep leaking on me at the firewall!!!??? 67RTBlue 7 5,575 02-20-17, 11:07 PM
  Sealing heater hoses to core 67RTBlue 14 9,158 09-04-16, 09:57 PM
  Valve body question tgranthamfd 2 2,771 02-22-16, 02:16 AM
Last Post: tgranthamfd
  Brake drum/wheel stud question rlsbee 13 5,967 02-02-16, 11:45 PM
  Distributor question 67RTBlue 9 6,884 01-09-16, 11:13 AM
Last Post: 1badstroker
  Brake line question-passenger side line hump or no hump? 67RTBlue 2 2,934 01-07-16, 11:12 PM
