68 383-2 block vin #s question
Recently bought a 68 Coronet 500 convertible. It's a 383 2 bbl. Supposed to be the original motor but I can not find any vin #s or stamping pad. Checked the top near transmission, and lower lock near oil pan. Has the machined pad on top with 383 non hp stamps. So question #1 is: where would the #s on the block be or are not? It has 8 1 67 cast on the block, from what I read Chrysler started adding vin stamping to the block for 68, did that start with blocks cast in 68? So not sure whether this block came with or without vin stampings?
TIA Mike
From what I understand, it's a crap shoot whether 68's got a VIN stamped on to them or not.
What is the build date of the car? That may be the best gauge to see whether the block came with the car or not.
October 18 1967. I thought if it was a replacement motor it would have the pad but no numbers stamped?
Some, but not all 68 motors had the VIN stamped on the top of the block by the bellhousing. (think maybe only HP motors got this?) So the motor could have been replaced, but there's no way to tell for sure.
The date of the car build sounds about right for the date of the motor being cast. What's the build date of the motor itself? (not the casting date, but the build date on the engine stamping pad)
It's 9 27 under the D383.
Thanks for the input.
Engine block cast Aug, assembled late Sept, car built mid-Oct... very good chance it's original motor.
VIN is WP23G correct?
No this is a vert, WP27G8G144xxx dash #, the fender tag is WP27G8G119xxx
That's another thing that was concerning! The dash vin is the order number and the fender tag is the serial number or whatever it's called, that do not match. I didn't realize this and thought the dash was changed out but I have the original title from the original owners and found the vin matched the dash #s. This is a learning experience! The oldest mopar I owned was a 70 Cuda and a 70 Challenger, they're vin #s match (fender tag and dash tags) 68 seem to be the year of changes.
Thank you for your expertise!
Mike
  In Search of '70 Big Block AC Discharge line RHORNE14 2 2,573 06-15-21, 10:28 PM
Last Post: 31ctg
  69 convertible 500 rocker panel question 31ctg 8 29,362 11-23-19, 06:25 AM
Last Post: MarkMopar
  Disc brake question for my 67 Piper 36 30,564 04-27-19, 08:22 PM
  Rusty bare block mike1968rt 1 16,280 06-10-18, 04:06 PM
  Old question with a twist sirjustice 2 15,075 12-13-17, 01:04 AM
  Noob on teh lookout with a question: Engine color Dingusboy 4 3,494 08-24-17, 04:09 PM
Last Post: Dingusboy
  New short block value? theman440 2 2,708 05-24-17, 08:21 PM
  Question regarding Coker tire and the BF redline radials 67RTBlue 3 4,174 11-23-16, 02:34 PM
  Tough question hopefully someone can answer! Warhawkfight34 3 3,257 02-23-16, 04:10 PM
  Trunk Spatter Question OldSkool 8 4,843 10-17-15, 07:51 PM
Last Post: dartforforty
