LWR control arm shaft sleeve removal tip
After you press the shaft out of your lower control arm to replace the bushing, you still have the inner sleeve pressed on the shaft to tackle.
One way I found easy and no damage to shaft is to tack weld a washer on to the sleeve and that gives you something to press on. I used the press but after it is hot from welding on it will be easy to tap out in a vise with a soft punch.
I'm a cheapo so I even cut the tack off the sleeve to use washer againSmile
Another option is if you have a cut off wheel, you can cut a groove in it, then smack it with a hammer and chisel or a air chisel It will break enough to the slide off the shaft with pliers.
4026
The words of experience! I am agreeing with both these posts because I have done the very same things. I'm a cheapo as well, I'd rather expend muscle and broken skin then spend a buck if I can get away with it. Couldn't have gone through all these years fixing my own machines unless I had that attitude!
I have done it the cut off wheel way, but the other way is a good idea. I would not call it the cheap way, I would call it the smart way.
Sometimes just welding a bead on it will expand (from heat) it enough to get it off.
My method usually involves a hammer and chisel...then a bigger hammer...the an even bigger hammer...then occasionally a completely new piece of whatever I'm working on.
That's because you don't use the proper tools. 4029
If I included that, I'd have no hands left.
  Videos of torsion bar removal? Xpsyclonex2002 0 27,800 02-05-19, 04:00 PM
Last Post: Xpsyclonex2002
  LCA Bushing Sleeve 67440Dodge 1 4,743 05-07-14, 11:08 PM
Last Post: 4264door
  Sludge Removal? tgranthamfd 16 12,647 01-27-14, 02:52 PM
  Removing lower control arm bushings 67r/t4speeder 0 3,954 06-18-13, 03:12 PM
  Valve spring removal with head on car and no air compressor 67440Dodge 3 5,604 02-11-13, 02:27 PM
