The Max build = 1967 R/T 440 4-speed Dana-60
#61
Haha!! that is one spooky guy
A very interesting man in a very interesting movie my friend!
[Image: The-Silence-Of-The-Lambs-Widescreen-Spec...LINC-L.jpg]
Yes and I watched it once and no more.
Very good don't get me wrong just too spooky for me.
[Image: th?id=HN.608045091461662891&w=210&h=188&...=1&pid=1.7]
My dream 440 is a stroker but it will still be a while until I can afford to do it right and my 426 is a loosey goosey and drinking oil like its ice tea.
And a friend of mine has a `Cuda he is restoring ( same one one we saved from a backyard a while back I posted pics of)and it has a 440 that he wont be putting back in, so I bought it from him to get me by for a while. It is a bit more radical than I want but it the price was right and it will be a fun experiment. The 440 has estimate of 30 miles on it and the builder is well known in our area for putting together killer Mopower. Since built it has gone three trips down the 1/4 mile, then did a local cruise night/car show then one more 1/4 mile run, then Preston bought the car and we took to Saturday morning Donut meet once.
So this engine is still very fresh, but I know sitting around isnt the best thing for any engine, so I am going to tear it down and inspect everything and see how it looks. Outside looks bad because the guy Preston bought `Cuda from left the car the the backyard covered at least and the aluminum parts corroded like the cheap chrome t-stat housing.
So far I haven't done much other than pull rocker covers and pan and it looks like new and cross hatch in cylinders is barely marked. 1969 440 with 2951908 rods , 915 heads , still waiting on cam card and all the paper work on build.
more updates soon
nice! it sounds like you have a good motor there. engine building is my favorite part of building a car, body work least favorite.
Please do another burnout video when you get the new pump in Andy.
theman440 Wrote:Please do another burnout video when you get the new pump in Andy.
Another burnout? Did I miss one????
Little sneak peak inside this afternoon, I just had to pull the heads to make sure it was fine. Only thing that bothers me so far is builder estimated it has 12.5 compression, I just don't see any pop up pistons or signs that that could be.
One rocker lash at zero on #8 intake and not sure why so I will take another look at that.
Builder may think that because of the closed chamber 915 head and I bet there was a steel shim head gasket in it.
It's gotta be 10.5 to 11 if the head was shaved .010.
Stock felpro gaskets
I would like some thicker gaskets though
any suggestions?
I found an issue with valve seat on 8 intake so it needs fixed also, all others look straight with straight edge anyway....backyard style
  My Dart build 67r/t4speeder 349 118,177 10-23-25, 05:38 PM
  Project "YANKEE EXPRESS" 1967 Coronet aslbow 19 11,431 11-04-15, 04:17 PM
Last Post: aslbow
  My new 1967 coronet 500 Gatemindr1 8 6,576 07-13-15, 10:22 PM
Last Post: Gatemindr1
  Just a note..1967-1970 is the FIFTH Generation of Coronet! TekHousE 7 5,973 08-04-14, 02:07 PM
Last Post: TekHousE
