54 Coronet Build
#31
I'm liking your project '54 a whole lot! Keep up the good work!
My parts book show the rear drum the same for 39 to 54 for the 6 cylinder and the same for for 53 and 54 for the V8. You may be able to press out the old studs and replace with right handed studs.
Thanks 48mirage for the info.... But after doing more research I felt it was more practical/cost effective to get a rear end from junk yard. I picked up a 1987 Chrysler Fifth Ave rear end for $240 with drive shaft.
3581
Cut off perches and did a dry fit
3582
Wow maybe too low???
3583
Sitting on the ground... Actually just what I was looking for!
3584
Now I need to crawl under and tach weld my perches. Then I'll remove the rear end and complete welds and replace seals, brakes and a little clean up.Big Grin
Gonna be nice!
Still been working on the 54 and other projects... Here is a few pics to show you whats done...
Cleaned up and completed installing rear end...
5762]
Had a friend weld up my steering linkage. Got them installed and competed steering...
5763]
Completed motor and got it started! Sounded great and quick response! No leaks!!
5764]
Got the drive shaft custom made and balanced.. Sorry no picture.
Hugged and narrowed rear bumper.. Sorry no picture. I will try to post one.
Hugged and lowered front bumper...
5765]
Removed old front brakes...
5766]
5767]
And installed new disc brakes from Scarebird (and basic parts from parts house)
5768]
5769]
5770]
5771]
Next I will replace master cylinder and run new brake lines. Smile
That's going to be a great ride when you're done!
lookin' good!
  Rear axle replacement for '58 dodge coronet acer 3 20 06-06-24, 02:15 PM
  '58 Coronet Windshield Wipers acer 1 29,589 06-09-20, 03:41 PM
  1956 Dodge Coronet Parts for Sale higbull 0 29,969 07-20-18, 03:14 PM
Last Post: higbull
  1/18 scale Coronet Club Coupe Jim 68cuda 0 12,244 06-09-17, 04:20 PM
Last Post: Jim 68cuda
  Wiring: Accessibility at 1950 coronet crnet50s 1 13,757 01-03-17, 10:36 PM
  50 coronet wont start 50net 18 21,343 09-27-15, 08:46 PM
Last Post: 50net
  1958 Coronet Wheel offset? samdjr74 0 3,956 08-04-15, 11:49 AM
Last Post: samdjr74
  50 Dodge coronet sierra steel woody wagon johnson3900 4 5,834 09-01-14, 11:17 PM
  "50" odd banana coronet 50net 0 4,322 01-05-14, 04:01 PM
Last Post: 50net
  Need help keeping the Throttle Level attached to the Throttle Body, On a 1952 Dodge Coronet 52-Coronet 1 4,149 10-11-13, 07:06 PM
Last Post: 48mirage
8 Guest(s)
