Tire question
Need to replace the 20+ year tires that are on the car....they were flat and have some dry cracking. What is the max tire size I could fit in the rear on the stock rims? I like the look of a wider tire in the back and narrow tire up front.
Are they 14"? Because if they are, your selection will be much more limited than with 15"
i used to have a 70 coronet with 14x5.5" wheels. it had 235/60 in the rear and 225/60 in front. i would think it could work on a 65 too. my 65 has 15x7 rear w/255/60 and 15x6 front w/ 215/60, (torque thrust wheels)
Yes I have 14" rims for now....maybe I'll just put a cheap replacement on for now...then convert to a 15" cragar.....tell me your opinions on them.
15" really helps fill the wheelwell!!
  69 convertible 500 rocker panel question 31ctg 8 29,362 11-23-19, 06:25 AM
Last Post: MarkMopar
  Disc brake question for my 67 Piper 36 30,564 04-27-19, 08:22 PM
  Old question with a twist sirjustice 2 15,075 12-13-17, 01:04 AM
  Noob on teh lookout with a question: Engine color Dingusboy 4 3,494 08-24-17, 04:09 PM
Last Post: Dingusboy
  tire size 65 coronet danielgbrooks@yahoo.com 2 2,946 04-25-17, 03:24 PM
Last Post: 4404spd
  Tire and Rim Size JimKueneman 8 6,048 11-29-16, 12:51 PM
Last Post: Mopars & Missiles
  Question regarding Coker tire and the BF redline radials 67RTBlue 3 4,174 11-23-16, 02:34 PM
  Tough question hopefully someone can answer! Warhawkfight34 3 3,257 02-23-16, 04:10 PM
  Trunk Spatter Question OldSkool 8 4,843 10-17-15, 07:51 PM
Last Post: dartforforty
  Washer Bottle question OldSkool 9 4,355 10-09-15, 11:26 AM
