54 Coronet Build
#41
How did the scarebird kit fit?
Did you remove hood center trim if it had any?
Keep those updates coming for us to enjoypopcorn
And congrats on firing the engine, that is always a happy day for sure .
Thanks everyone for the positive feedbackBig Grin
The Scarebird kit was great!! Very easy to install. The only thing I could say is that the kit came with a list of parts needed. I shopped around and the brake rotors were cheaper at autozone, so I bought them there. But when installing them they did not clear the hubs. I brought the hubs down to napa and their rotor fit over perfectly. So I bought rotors there and returned other ones. That what I get for trying to save a couple bucks....
I did remove the ram on the hood. My car was originally a 6 cylinder. And since it now has a V8 I wanted to used the Hemi V8 hood emblem. I like the look better Wink Thanks again for positive feedback and I will keep posting....
I have used the Scarebird kit on my '49. In researching the kit, I learned that Scarebird did all of their mockups with NAPA parts.
Mirage... Are you using the stock master cylinder? If so are you happy with the stock one? I ask because I thought about using a on frame universal master cylinder, but I think it the trans cross-member will be in the way. So I'm thinking stay with stock master???
Check you PM's.
Definitely don't want to use stock master I would think. Even if not power, manual dual pot will work fine for a cruiser .
My two cents
  Rear axle replacement for '58 dodge coronet acer 3 20 06-06-24, 02:15 PM
  '58 Coronet Windshield Wipers acer 1 29,589 06-09-20, 03:41 PM
  1956 Dodge Coronet Parts for Sale higbull 0 29,969 07-20-18, 03:14 PM
Last Post: higbull
  1/18 scale Coronet Club Coupe Jim 68cuda 0 12,244 06-09-17, 04:20 PM
Last Post: Jim 68cuda
  Wiring: Accessibility at 1950 coronet crnet50s 1 13,757 01-03-17, 10:36 PM
  50 coronet wont start 50net 18 21,343 09-27-15, 08:46 PM
Last Post: 50net
  1958 Coronet Wheel offset? samdjr74 0 3,956 08-04-15, 11:49 AM
Last Post: samdjr74
  50 Dodge coronet sierra steel woody wagon johnson3900 4 5,834 09-01-14, 11:17 PM
  "50" odd banana coronet 50net 0 4,322 01-05-14, 04:01 PM
Last Post: 50net
  Need help keeping the Throttle Level attached to the Throttle Body, On a 1952 Dodge Coronet 52-Coronet 1 4,149 10-11-13, 07:06 PM
Last Post: 48mirage
6 Guest(s)
