Disc brake question for my 67
Nice work Kevin. I'd love to be doing that instead of the desk work I have to do now.
thanks its all coming together nicely..should have some update pictures over the weekend!
These bump stops look too high would do they need to be cut down to?
Factory ones are about 1.5"
Thank you!
Still waiting for some parts to trickle in I upgraded to the 11/16 tie rod ends
I am really off to a slow start as I'm still waiting for some parts but got out there and did a couple things today.
I can't thank Mike enough for the steering Box he gave me years ago the difference between what came off car and this one seems to be night and day.
I set the shocks for 80/20 they should work well with the caltracs
The poly bump stops dont work no matter how much I cut and resize it seems it needs about an inch clearance as not to bottom out...I need to find some stock ones
Also is there some adjustment to the lower control arms I need to do it seems like they're pulling the the uppers down and bottoming out
Torsion bars still had some tension arm so I'm past that now those poly bump stops are still way too big
Are you talking about the upper bump stops or the lower stops?
Last Post: MarkMopar
  Old question with a twist sirjustice 2 15,075 12-13-17, 01:04 AM
Last Post: Dingusboy
  Question regarding Coker tire and the BF redline radials 67RTBlue 3 4,174 11-23-16, 02:34 PM
  Tough question hopefully someone can answer! Warhawkfight34 3 3,257 02-23-16, 04:10 PM
Last Post: Warhawkfight34
  Trunk Spatter Question OldSkool 8 4,843 10-17-15, 07:51 PM
Last Post: dartforforty
  Washer Bottle question OldSkool 9 4,355 10-09-15, 11:26 AM
  Dodge Challenger Question Histoy 3 3,387 08-04-15, 02:14 PM
Last Post: Histoy
  68 383-2 block vin #s question slimert 6 4,270 04-08-15, 10:56 AM
Last Post: slimert
