Power Brakes VS. Manual
honcho Wrote:Hey Avenger,when going to dual line MC,the big pod goes to the front brakes and be sure to curl the lines
I have always wondered, what does curling the lines do exactly? Confused
-John
[Image: IMG_1711.jpg]
It gives the hard line some flex area
Also, the bigger pot denotes it's a disc brake MC. (larger area for the fluid to react against means it needs a bigger reservoir)
The rear line is still stuck...soaking the heck out of it with PB...hoping for the best in a day or two...also all the fittings are rounded so vice grips or channel locks to get it out. Sad Its also difficult to get at because its between the frame rail and the torsion bar Sad
-John
Your best bet is to either replace the lines with new, or make them. Making them is one of the easiest things you could do once you learn how. All you need is some 3/16 line and nuts. A lot of time you can reuse the origional nuts unless rounded off. The special size nuts can be had as well.
good luck.
Yeah my neighbor said (he own an autoparts store in town) he has been helping me and that we could put a new one in and put a new T for the lines and such...i may have to go that route. ill try to pull it off again tonight after its been soaking in pb all today and last night..hope for the best...luckily lines are cheap lol
-John
What Rich said, keep your old lines for a pattern, that's what I did.
  Power Steering Pump NZ 68 R/T 4 16,696 02-16-20, 03:55 PM
Last Post: NZ 68 R/T
  Bleeding New Brakes Piper 26 10,516 07-10-17, 12:08 AM
Last Post: Piper
  I'm published in Chrysler Power Magazine! TekHousE 5 4,555 12-28-16, 12:30 PM
Last Post: o.dima
  My car is on the cover of the upcoming month's Chrysler Power! TekHousE 19 9,221 04-14-16, 11:20 PM
Last Post: R/T XTC
  My car and story is in this month's Chrysler Power Magazine TekHousE 22 8,516 10-08-15, 04:05 PM
17 Guest(s)
