How does OD and lock up work? One switch for both or are they separate? I buggered up my Cummins van when the TPS went bad. I had two switches, one for each, and boy you knew it when I forgot to shut it off. LOL
Threads: 477
ws27 Wrote:How does OD and lock up work? One switch for both or are they separate? I buggered up my Cummins van when the TPS went bad. I had two switches, one for each, and boy you knew it when I forgot to shut it off. LOL
There are a couple ways of hooking it up, I went simple toggle to get started with then maybe a couple solenoids later. For now both grounds are connected to the brake light switch so it releases at least for emergency slow down.
That's a great idea, I wish I thought of that with mine. A Cummins motor will NOT stall out when you fail to disengage lockout and you try to stop.
Threads: 477
"How much you figure you gotta get the driveshaft cut?"
The drive shaft was shortened 7 inches, and balanced.
Threads: 477
Transmission is in and working great. Just need to fine tune my drive line angles, it has a very slight vibration at around 60 that I don't think I had before. I made the transmission mount to where you can shim up or down some so that will make it easy.
Threads: 477
65rbdodge Wrote:I love the 323's in my desoto with the overdrive, 2100 rpm@65mph w/205/60/15
I see why now, I really like mine with 3.23 also now I have some miles on it.
Threads: 477
I was chasing a vibration after my swap, I swore was the converter well I was wrong. Yesterday I found it to be the poly transmission mount that I used, I put a rubber #2360 one on and all fixed. The whole car feels better now I am very happy.
Threads: 477
Just hit 1000 miles with new transmission swap and am very happy, no leaks in the engine or trans. I need one tooth smaller speedo gear put in then do a mpg check, I know it still won't be great mpg but better than it was and saving high rpms on my 340 at the same time.
drive drive drive
Threads: 37
Bio: Retired generational Mopar family person.
Love life, God, family, The Great White North and of course….. All of my Mopars
11-17-16, 06:41 PM
(This post was last modified: 11-18-16, 01:03 PM by 4404spd.)
Have you noticed mileage being any better ?
What vehicle did you put it in ?
The "Alberta" Andy.
1000 miles already? Boy you sure drive a lot!
Does that mean you need a hotel reservation for Carlisle 2017? Huh?
