Standard VS. Automatic
So with a stock converter how radical of a cam have you seen people use ?
BooBoo Wrote:So with a stock converter how radical of a cam have you seen people use ?
A "RV" cam is your limit with a stock converter IMO
65rbdodge Wrote:if you car is a 383 it has a 727, to my knowledge 904`s never came behind a big block. i have an 400/727 in my dart with a griner(spelling?) manual valve body, i can say it pretty fun to drive and shifts really hard. i feel in control more with the manual valve body almost like a 4 speed.
Did you have to add anything else other then the manual valve body to get it to shift hard ?
theman440 Wrote:Another cool thing about a reverse manual 727 is that there is no engine braking in first gear. I also dig how the engine revs up really high before the car moves when you have a high-stall convertor
Please explain . I dont know what you mean by engine braking in 1st gear . I understand 18 wheeler engine braking . Are you saying the trans ACTS like it has a stall converter ? Thanks . BooBoo
BooBoo Wrote:Please explain . I dont know what you mean by engine braking in 1st gear . I understand 18 wheeler engine braking . Are you saying the trans ACTS like it has a stall converter ? Thanks . BooBoo
What it means is that when your in first gear and you let off the gas the engine free wheels (trans does not drag engine rpm down)
Oh , OK . What about when your sittin there ideling ? is the car trying to pull off or do you have to bring the RPM up like a stall converter ? If so about how much RPM is needed to get the car moving ? I,m just trying to figure out if I can use a radical cam with that set up .
let me clear up the engine braking in first gear. some have it and some dont. to get technical, it called "low band apply" here is what happens, say you are driving and want to slow down using the trans. you manually shift into 2nd gear, you slow down some, and then shift into first. without low band apply it will be like shifting into neutral, with low band apply, you will continue to slow down. without low band apply as you are coasting and the engine is ideling like you are in neutral, you hit the gas and the engine revs until it catches up to the speed of the car the the car takes off(this is bad for the trans.) as far as i know griner valve bodies have low band apply and cheeta does not.
OK I got ya , thanks .
Just wondering why you would not want to not a have low band apply?
Something to do with drag racing, keeping RPMs up on a burnout?
67r/t4speeder Wrote:Just wondering why you would not want to not a have low band apply?
If you're asking me , I want to use a cam with a real choppy idle . So I'll probley need something that acts like that , like a higher stall then a stock converter . BooBoo
  Dodge 727 automatic conversion to a833 4 speed Lipers1 9 6,339 08-04-15, 01:18 PM
Last Post: Warhawkfight34
