Engine problems all opinions welcome.
Well my season is over for my baby. Bringing it in my shop pulling the engine to get some MAJOR SURGERY! No power and I can hear my pistons slapping around pretty hard. Probably going to bring it to PK machine shop and hopefully will have it ready for next year. Kind of sucks but I've been wanting to rebuild it anyway.
Oh no! I hope they can pinpoint the cause.
Jason, piston slap, although not good, won't cause a significant performance issue. You might be able to fix the issue at hand and get a couple of months more before you rip it apart.
Down on power? Id say spun bearing..
ws27 Wrote:Jason, piston slap, although not good, won't cause a significant performance issue. You might be able to fix the issue at hand and get a couple of months more before you rip it apart.
I changed the plugs, cap and rotor, checked the oil (no metal in it) I am thinking of pulling the valve covers next.
Whatever it is it sounds absolutely horrible, barely any power and practically feels like it is going to shake itself apart.
Probably going to pull the valve covers tonight, start it up and take a look.
Is the sound up top? Or down low? A pipe can be used to listen. Up top you could have a bent push rod or two. Down low would mean spun rod bearing. And that`s bad!
Hibbing_Coronet_500 Wrote:Is the sound up top? Or down low? A pipe can be used to listen. Up top you could have a bent push rod or two. Down low would mean spun rod bearing. And that`s bad!
I am thinking a spun bearing!
I would think a spun bearing will cause lots of noise and will result in catastrophic failure but won't make it run bad. Is it running on all cylinders? And have you tried pulling one plug at a time at least to determine which cylinder is not working?
I'm just throwing things out there.
ws27 Wrote:I would think a spun bearing will cause lots of noise and will result in catastrophic failure but won't make it run bad. Is it running on all cylinders? And have you tried pulling one plug at a time at least to determine which cylinder is not working?
Yup, I've changed all the plugs, cap and rotor and there were some that were pretty bad but I've seen worse. I did not take off the valve covers yet though, that is next when I have time.
Just throwing it out there. Any chance you pulled the distributor and didn't get it back in its original spot? Or maybe crossed a plug wire when you installed the new cap? Cross wired plugs will sometime let an engine run but poorly.
if you have a compression tester hook it up to spark plug #1 with compression gauge removed. You just want the rubber tube hooked up. Pull the coil wire and crank the car slowly, when the hose hooked to #1 hisses loud it's coming up on #1 compression stroke. When that happens the distributor rotor will be pointing at (or slightly past) the #1 spot on the dist cap. Once your certain of #1 You can check the firing order. It's always best to find #1 yourself and not rely on the #1 location shown in the shop manual.
just a thought but worth a few minutes to check.
  VIN number problems theogonzalez 2 24 07-27-24, 04:58 PM
  VIN number problems nhranut 2 4,739 06-02-20, 09:20 PM
  I would love guidence and opinions about upgrading my worm out 318 poly pistolero5150 6 4,254 12-13-19, 01:23 AM
Last Post: stonehengeheels
  Recommend engine swap shop fitzyb5 2 2,937 10-13-17, 11:25 PM
Last Post: Dingusboy
  Looking for 67 R/T engine bay pictures jworz71 12 8,387 12-19-16, 11:13 PM
Last Post: jworz71
  Engine and transmission questions odot365 14 9,158 08-21-16, 09:21 PM
  Anyone have problems with keystone clamps? Warhawkfight34 1 2,838 05-29-15, 12:07 PM
  383 cylinder head opinions Mark's 69 4 4,450 03-22-15, 08:36 PM
Last Post: Mark's 69
  Almost done detailing the engine bay. Heres some updated pics. Warhawkfight34 16 10,511 01-26-15, 11:37 AM
Last Post: Warhawkfight34
