Custom has the idea, it clips only on the metal parts though and rubber flex hose in middle. Making a solid ground connection from pick up tube to fuel line going to carburettor.
Custom66coronet Wrote:Yes it connects the fuel line to line coming out of the tank. over the piece of connector rubber hose. and provides the ground for the fuel gauge.
X2!
Yes tank secured tightly to trunk with straps.even temp.ran a grd wire from top of sender to body.still have to trace out wiring under dash.developed another project bleeding brakes line near engine bay started leaking, so that will be next ,changing brake lines
