03-07-14, 02:57 PM
I know a couple of guys with them and the really like them.
overdrive choices for big block
03-07-14, 02:57 PM
06-04-14, 05:08 AM
The GEAR VENDORS unit is very stout and pretty easy to install. To my knowledge there is not a BB/RB overdrive tranny that will bolt right in. Many have gone to a GM L-60-E and but an aftermarket bell that will bolt to your motor. This requires cutting off the factory bell and using longer bolts into the front pump.. Also requires adapting your shifter and kick-down and sending in your convertor to have it modified to fit.
So for the money I think the gear vendors unit is the best.. Also you can shift between gears using the OD unit.. Check: http://www.gearvendors.com/
08-16-14, 09:55 PM
i went to mopar Nats last Saturday in Columbus,Oh: Passion out of PA know has available a bolt in application for A-833 bell housings; They call it a A-855 5 speed manual $4500.00 complete check it out
08-16-14, 11:24 PM
There is also a year wait for that trans.
08-17-14, 12:32 AM
67440Dodge Wrote:There is also a year wait for that trans. Party pooper! LOL
08-18-14, 08:17 AM
an a500(light duty) or a518(heavy duty) are able to fit behind a big block with an adapter and a few other mods. the adapters are just under $500.
08-18-14, 01:09 PM
I have a tremec 5 speed in my car with a 3.54 rear end. 2300 rpm's @ 70 mph 2700 rpm's @ 80.
Small Block EFI | Derwud | 3 | 14 |
10-09-23, 03:11 PM Last Post: 67440Dodge |
Overdrive for the non-slush box crowd | 67440Dodge | 9 | 19,753 |
02-29-16, 03:14 PM Last Post: 67440Dodge |
Users browsing this thread: |
5 Guest(s) |
