05-04-13, 10:05 PM
Trying to get my 68 Charger wired up and running
I took the cluster out, did the white face gauge thing and while it was out took the opportunity to change all the bulbs (everything was pretty much burned out so I started fresh)
The wiring forward light harness was shot, so I bought a used/working one (Im already thinking that the issue) purchased two new marker lights plugged in all in and here are the issues I have now
The black wire that goes on the alt gauge gets hot hot hot hot..man like really hot just with the key switch on (I checked the grounds and the cluster is also grounded)
all the lights turnsignals work with the exception of the driver side turnsigal is dim when it blinks when and the parking light (same fixture) simply wont turn on everything on the passenger side is working
ok..where do I start?
Beer!
Beer!
