New bullet for the "Brick"
#61
Got some more parts in - these are for the transmission. Lightened sun shell and aluminum forward clutch drum. These along with the transbrake & low gear set will be the only changes to the transmission besides a freshening. I'll cover more on this later.
1173611735
Well,
I have finished the block water jacket fill (some time back) now the block is at the machine shop for a line bore and to get the deck squared. I finished the idiot light panel, I wired in a 6-pin connector for easy removal if needed -
11747
11748
I wanted to clean up the wiring while the engine was out. I had a few wires going thru the firewall via misc. holes. I will now have most of them pass thru the factory bulkhead connector. The bottom row of the upper connecter now houses the oil pressure, water temp, alt light & trans temp circuits. The bulkhead connector used Packard 56 series terminals.
11749
11750
I am also updating the brake system - new Strange master cylinder with the line-loc relocated to the the master via a Jegs bracket.
11751
I had to build all new brake lines for the front brakes and install a new proportioning valve.
11752
11753
I also needed to do some paint repair on the firewall - the old master seeped a bit.
11754
11755
New and refurbished parts ready to be installed -
11766
Old set up -
11760
New set up -
1176111759
I whipped up a drawing and had some brackets water jet cut - these will adapt the mustang brakes to the Dana 60. I still need to weld on some 5/16 thick spacers to them and drill some holes. They will bolt and weld onto the axle tube flanges.
11762
I took the wiper motor off to clean it up and replace the gasket. I also covered the wires with split loom - I will be doing this with all the under hood wiring.
11763
Got some more parts in too -
1176411765
What brand prop. valve?
Nice work your on a roll
Looking great! I especially like the packard crimps. I always struggle with the insulation crimp on the packard connectors - the wire crimp is fine. Don't think I ever did find quite the right crimper for the insulation............
[quote=markz]Looking great! I especially like the packard crimps. I always struggle with the insulation crimp on the packard connectors - the wire crimp is fine. Don't think I ever did find quite the right crimper for the insulation............[/
I had trouble with the wire crimps on the male terminals. I had to file the tangs thinner to be able to crimp them, the females were easy.
Andy,
The prop valve Is a Jegs copy of a wilwood valve.
theman440 Wrote:Andy,
Thank you
Idiot light panel installed - I decided to clean up the dash before I installed it then I noticed how crappy looking the dash knobs and bezels were, so I cleaned them up too.
11768
11769
I used CLR, tooth paste and a tooth brush to clean all the knobs & bezels - not show quality but much nicer than before -
11770
Radio knobs - Left after, right before
11771
