New bullet for the "Brick"
Update -
Got the intake back from the machine shop and the pushrods are being made now.
Finished up the cap ends of the plug wires. I had to buy a single MSD 8.5mm wire and re-do the #8 wire (too short) Can you believe a single wire costs $35!?
[Image: img_20211005_210832423-jpg.1175751]
[Image: img_20211005_210840388-jpg.1175752]
Glad to hear about your friend!
I'm surprised you didn't have to wait til March for the plug wire.
theman440 Wrote:Update -
yessir… almost cheaper to buy a whole spool I think!
Started making intake gaskets -
[Image: img_20211005_212042164-jpg.1175753]
[Image: img_20211005_213051039-jpg.1175754]
[Image: img_20211005_213342645-jpg.1175755]
Update -
I glued the gasket material to the flange then I cut out the port openings and bolt holes with an exacto blade.
[Image: img_20211015_200235125_hdr-jpg.1180355]
Done -
[Image: img_20211015_210809994_hdr-jpg.1180356]
Now its' time to clean it and paint it - should get that done this weekend.
I bought another cleanable oil filter for my engine, this one is much smaller and wont interfere with the oil pump pick up line, I bought it from Bob Mazzolini Racing. it's expensive but I sold my System 1 filter for $100 so that made it easier to swallow. It is really trick. it's machined from billet and comes with a socket to install & remove it. Id say the only draw back is it will reduce the total oil capacity of the engine.
[Image: img_20211015_195424243_hdr-jpg.1180375]
Nice looking filter there
  • [INDENT]More assembly, getting closer. I had to "install" both rocker assemblies twice. The left side had the exhaust rockers in the wrong spots so I had to remove it, swap rockers and re-install. Then on the right side I forgot to make sure the rocker shaft spacers were in the right spots, so I removed to check - good thing I did because the right side rockers would have been oil starved.
    [Image: img_20211019_200537406_hdr-jpg.1182429]
    [Image: img_20211019_214614133_hdr-jpg.1182430][/INDENT]
Looks really nice Jeff
Them rockers prob cost more than my GV unit!
