15" Magnums
I've had a set of Magnum 500's on order since April. They are backordered thru Summit who gets them from Wheel Vintigues. Wheel Vintiques says they don't have the parts to build them. Called Specialty Wheel co and they don't have 15x6. Plan was to run 15x6 in front and 15x8 in the rear. Is anyone running 15x7 in the front and if so what tire size?
Thanks
Matt
How about some 17"s.10896
Love the billet wheels, not the look I'm going for on this car though. Your car is beautiful!!!
Looks cool. That matchbox car look. I'd get points off at shows but I'd like a set for my resto mod I'm building. 67 R/T convert triple black with 426 Hemi + 4 speed. Big brakes need the big wheels. Now I know how it would look on mine. nice.
Jim
I have 15x7 mag 500's all the way around because they were only available at time as well. I have redline poly's F70-15. You might try using tirerack.com tool to match rim size with radial size.
Jim
I have 15" x 7 craigers on my Dart with 225 70 15 radials. but 245 60 15 Im told will work too
There's got to be some other company that has them in stock, jegs, check Ebay maybe.
There are, but wheel vintiques supplies to most companies. Going to try Specialty Wheel again tomorrow to see about 15x7's.
If you call around you might get lucky and find someone who has them on hand if your sure what back spacing you need.
So I called Specialty Wheel back, and got someone else. He was able to locate two 15x6 and wheels and tires are in route. Thanks for the help!
