Fan shroud.
Has anyone ever run their car without the fan shroud? How much of a cooling problem would it be?
With a more efficient radiator than the stock one would it be a problem without the shroud?
I'm running a three row aluminum radiator and still needed to put the shroud back on to keep cool. But now I can idle in traffic in 100+ degrees temps with no problem.
I am going to probable have to modify a shroud to fit! My radiator is good for up to 600hp and see what happens.
No fan shroud here............
No over heat problems
5 blade fan with fan clutch
  radiator fan shroud for 69 Coronet R/T moparmike80911 11 8,858 07-12-14, 12:57 AM
Last Post: moparmike80911
  Fan shroud question? Warhawkfight34 1 2,486 06-19-14, 08:41 AM
