03-28-17, 02:24 PM
Does anyone know where I can get some new sway bar bracket bolts for 69 b-body coronet? Can't find them.
sway bars bracket bolts?
03-28-17, 02:24 PM
03-28-17, 02:52 PM
Try jims auto parts . Not sure which bolt you need, bracket bolt at k member?
03-28-17, 03:59 PM
67r/t4speeder Wrote:Try jims auto parts . Not sure which bolt you need, bracket bolt at k member? Yes the bracket to the K member.
03-28-17, 06:28 PM
Aren't they just a simple 5/16 bolt?
03-28-17, 07:38 PM
I put grade 9 aircraft bolts in mine since I pop wheelies all the time.
03-28-17, 09:36 PM
Grade 9? You'll rip them off the k frame before they break?
03-28-17, 10:43 PM
ws27 Wrote:Grade 9? You'll rip them off the k frame before they break? Ooops over engineered again?
03-29-17, 07:53 AM
Ok, thanks guys. I'll get to my local store. Changing out my aftermarket sway bar with a factory restored one from Tony's parts. My aftermarket one was causing to many issues. I'll be glad to get rid of it!
03-29-17, 10:23 AM
Just in case people want the correct bolts RT specialties has them.
http://www.rtspecialties.net/proddetail....od=1000434 |
Check your nuts...and bolts and screws! | 67RTBlue | 6 | 4,213 |
07-20-17, 01:38 PM Last Post: 67RTBlue |
Torsion Bars | Cdub51 | 3 | 3,408 |
01-21-15, 02:01 PM Last Post: Cdub51 |
Mystery Bracket | NZ 68 R/T | 6 | 4,741 |
01-16-15, 06:02 PM Last Post: Avenger |
Rear sway bar install | honcho | 5 | 4,698 |
12-14-14, 05:52 PM Last Post: honcho |
Users browsing this thread: |
1 Guest(s) |
