did i do this right
sorting out the trunk9115]9116]9117]9118]9119]9120]9121]
Looks right to me. I'm missing the plug piece for the spare tire cover. Now that brings up a question: Is there two wing nuts? A large one that clamps the jack base and tire to the floor and then the small Wing nut secures the plug for the cover??
67RTBlue Wrote:Looks right to me. I'm missing the plug piece for the spare tire cover. Now that brings up a question: Is there two wing nuts? A large one that clamps the jack base and tire to the floor and then the small Wing nut secures the plug for the cover??
small and large wing nut any ideas about plastic bag
The jack hook and the tire iron go under the spare, that should make the board sit flat if the tire is not too wide.
Fish around with magnet or a mirror in the inner wheel wells, you might fine the holding spring for the jack . Or other goodies. I found a rotted pair of scissors in my Dart .
9137]9138]9139]when I unloaded the trunk threw the spring in a box with some other stuff thought it was a brake spring I think this plastic bag has something to do with car but maybe not working engine compartment now
Yeah, there are 2 wing nuts - one on top of the jack hook and the other to hold the board down. BTW anybody have one of those stamped wing nuts in Bookers photo? I need one, it is 3/8 18 thread, I could only find a cast one.
Where can I get the hole plug that holds down the cardboard spare tire cover???
I would think somebody here would have one lying around.
