10-18-15, 01:03 PM
Greetings -
I've had this car practically forever, but it's an original, and I'm taking some of it apart for literally the first time ever. So, lots of this is new to me, and I appreciate the help of those of you who've done this before. I'm putting new anti-sway bar links and bushings on my '67 R/T, and have a few questions.
Since my simple projects typically grow into more involved ones, I decided to remove the bar for restoration while I had the ends unfastened. My intent was to remove the mounting brackets, blast and refinish everything back to original, and install with new end links.
After getting the anti-sway bar out on the floor, it appears that the mounting brackets were factory welded around the bushings and bar. I'm assuming there's no non-destructive way to remove the brackets. Mine are in great shape, and original, so I'm not interested in replacing them. If anyone has a non-destructive removal method, please let me know.
Does anyone know the correct factory finish on the mounting brackets? Mine have a rust finish, so I'm assuming that they were probably either zinc plated or just left bare. Any ideas? Regarding the bar itself, I cleaned a portion of the center with a toothbrush, and found a non-coated, bare heat treated steel finish. Much like the drum brake backing plates, or leaf springs. This is the way I intend refinish the bar itself.
If I can't get the mounts off the bar, then I plan to scoot them back and forth, mechanically strip the bar and components, and refinish everything insitu. This will be harder than being able to disassemble everything and do the parts separately, but is do-able.
Cheers!
JD
Cheers!
JD
You can check out any time you like, but you can never leave...
