Threads: 79
Replacing the original engine and rear harness is strong possibility. If so who makes a good one? Would like to get a factory looking harness. Year one has them. Evans is another name that I've heard.
Thoughts?
Threads: 308
Year One sells the M&H Harness (they are the exclusive distributors for them). Evans is good also. I've used Evan's myself and liked the way it was put together, I've seen the M&H ones also, and they look like a quality product.
I like Evan's harness because they have great customer support, and if you need a special harness made up, they will do it for you.
Threads: 474
Installed two complete M&H harnesses and many engine harnesses really like them.
Threads: 40
I have a couple of Evans harnesses. Quality has not been good. Had issues with the wrong gauge wire and quite a few bad crimps. But price is right.
Threads: 474
67440Dodge Wrote:Year One sells the M&H Harness (they are the exclusive distributors for them). Evans is good also. I've used Evan's myself and liked the way it was put together, I've seen the M&H ones also, and they look like a quality product.
Classic Industries sells M&H also, I always double check when ordering that it will a M&H not something else but so far so good.
Threads: 118
I used all M&H from year one. I have actually called them many times and there customer service and there knowledge was awesome!
Everything was made EXTREMELY well and they have tried to make every piece exactly to period correct factory standards.
Threads: 208
Used a couple of the M&H wiring harnesses from Year One back in 2005/2006 during the restoration of my sons 1972 Dart Swinger that also uses one of the Mopar Performance electric distributor conversion kits and the M&H harnesses fit and have worked perfectly since they were installed! Very happy with M&H's quality and Year One's prices were competitive back in the mid 90's as well. I also have a brand new M&H engine and forward lighting harness by M&H from Year One that I purchased a few years ago waiting to be installed in my 66 Coronet 500 also.
