how the heck does this come off?
Driving me crazy
Is there an allen lock nut holding housing to tube near where lever goes in ?
6281]I think the two halves are screwed together and come out separately?
I don't think you will get it off without pulling the whole column. Just did a 67 Barracuda. It was a floor shift car but the concept is the same. The tube that goes through the center of the column was press fitted into that housing - did not see anyway of separating the 2 without damage but there was no reason to. Not sure what holds the tube at the bottom of the column (in engine compartment) but I suspect something does and that is preventing you from pulling it out.
At least that is how it was on the Barracuda column.
Hello Kevin,
If you have a copy of the Factory Service Manual for your Charger, there is a complete section regarding the removal and installation of the steering column assembly. Wink
for posterity it is an allen key
How did it come off? If I was a bettin man I would of bet it didn't come off that easy...........
I heard allen key and just put on my specs and there it was..a couple turns it was right off
now the turn signal switch is another story!
Piper Wrote:I heard allen key and just put on my specs and there it was..a couple turns it was right off
Interesting. So the 678 Barracuda is a different design. No allen screws on that column..........
Smile
  Steering box... what the heck is it? 67440Dodge 29 16,187 04-30-14, 06:32 PM
