04-20-15, 03:00 PM
I am rebuilding my 727 myself.
I have it apart and it looks real good inside. Today I will be driving out all necessary bushing and replacing them.
New clutches and steels. New rings and servo seals.
4 Pinion planets. And bolt in sprag.
Trans go manual valve to charge converter in park.
I want to put a end to the leaking! I know it due to converter drain back. Ultimately the converter oil fills a already full pan. Then fluid begins to seep out from where ever it can.
My thoughts are:
Buy a deep / extra capascity oil pan with proper filter extension to keep filter down into the pan.
Then use the same quantity of oil as if using a stock pan. (9 qts)
Now we have extra room in the pan for oil to drain into. Hopefully it will all remain below the pan to gasket seal.
Thus ending the seepage from a over full pan due to converter drain back.
Think it will work?
My thoughts are:
Think it will work?
