Primer and paint procedure the factory way?
[INDENT] Hello!
I'm restoring a Dodge Coronet 440 -66 and I would like to know the factory procedure of applying primer and paint.
I know that the body was dipped in black/gray primer up to half the firewall and then the red oxide paint/primer was applied, but how and where? Under? Inside? Luggage and enginebay?
I have seen the black/grey primer line inside on the firewall and dooropenings, but did they not paint above that inside at all?
How did they lay the topcoat? Only in doorjamb or in the whole car?
Was the undercarrie black, oxide red or topcoat?
Please, explain to me...! [Image: smile.png] [/INDENT]
That is a question that I think is extremely hard to answer. I know for a fact that the engine bay was fully painted.
The underneath was car color painted past the wheel wells and the inner frame rails. I know this because my car was never touched. It had all the original paint and under coating (which the factory undercoating was gray not black).I know that vinyle top cars were just primer on the roof. I can go abck and look at my restoration of my 69 and see how it was. I'll let you know what I find. As far as primer still not sure exactly. Good luck!
Here are a couple of some original paint areas on our '67.
Duplicate some factory runs??? Big Grin
  Looking for Paint Shop near Williamstown NJ 440net 5 428 03-03-23, 10:51 PM
Last Post: Piper
  Paint code for Engine Turquoise 67RTBlue 3 4,721 01-12-16, 11:54 AM
  67 500 badge on trunk panel paint codes mocam8 3 4,336 06-09-15, 01:32 PM
  Where to buy good touch up paint? Even possible? mykenytemare 3 3,622 09-16-14, 10:28 AM
Last Post: TekHousE
  Chrome Paint Marker Pen thebankerstoy 6 6,532 11-14-13, 02:43 PM
  Finding holes for trim pieces on body after paint SmartPatrol 2 3,323 10-31-13, 05:32 PM
  Need 67 TT 1 paint formula! ewing 6 5,837 09-14-13, 04:19 PM
  Paint job needed!! bob hackett 2 4,208 09-07-13, 05:00 PM
Last Post: bob hackett
