Earson Cams TQ20H
Was wondering if anybody might know the specs of this cam, it was in a 1972 340. I found specs for Pontiac and chevy, but couldn't find any for the small block Chrysler! I am thinking it is along the lines of a factory 340 cam, if it isn't the original? But anyway was trying to find lift, duration, and rpm range, at least? The engine has been rebuilt, at least, once!
  • Aspiration:
    • Naturally Aspirated
  • Block Type:
    • V
  • CID:
    • 340,
    • 273,
    • 318,
    • 340,
    • 360
  • Make:
    • CHRYSLER
  • Part Name:
    • Engine Camshaft
  • Year:
    • 1964,
    • 1965,
    • 1966,
    • 1967,
    • 1968,
    • 1969,
    • 1970,
    • 1971,
    • 1972,
    • 1973,
    • 1974,
    • 1975,
    • 1976,
    • 1977,
    • 1978,
    • 1979,
    • 1980,
    • 1981,
    • 1982,
    • 1983,
    • 1984,
    • 1985,
    • 1986
  • Advance:
  • Application:
    • 1964-1986 CHRYSLER 273,340,360,
    • 1967-1985 CHRYSLER 318
  • Brand:
    • Erson Cams
  • Cam Type:
    • HYDRAULIC FLAT TAPPET
  • Duration @ .050:
    • 214/214
  • Duration Advertised:
    • 292/292
  • Grind Number:
    • TQ20H
  • Gross Lift:
    • .449/.449
  • Lobe Center:
    • 112
  • RPM Range:
    • 1800-4800
  • Valve Lash:
    • .000/.000
Super low and mid-range power. Good idle, fuel efficiency and driveability. 4 barrel and headers recommended.
Sweet, sounds exactly what I need, and thanks for the information. That is the lift I was thinking it was, had no idea on the duration!
  Cams cams Cams 67r/t4speeder 0 3,278 06-18-13, 11:53 AM
