Bendix 4-piston calipers
Here is an option to replace your worn out leaking calipers if you have a Bendix style. `67 `68 maybe `69. On my car a few years ago these were not available so I had mine sleeved and it was a nice job but very expensive.
They show these as reman. but they are new castings, with a difference of no Bendix name on them.
And they do have a core charge but before you give up your old ones keep your outer two of the three bolts holding the two caliper halfs together as these are special drilled and tapped bolts to hold your brake line bracket, and the new ones dont come with them.
Rock auto # 184473 same as Cardone I believe.[Image: 184473-01.jpg]
$82.79 is allot cheaper than what I paid to sleeve mine at around 275.00 each.
Thanks for the info Andy, I had mine sleeved too, but the pistons were pitted and I had leaks between the seal and the piston at the groove.
Always wanted to just get replacement pistons.
http://harmonclassicbrakes.com/
these guys have piston kits Rich
67r/t4speeder Wrote:http://harmonclassicbrakes.com/
Ooooh, thanks Andy. I wonder if I should buy them before they stop producing them.
  Bendix Front & Rear Brake Drums thebankerstoy 5 6,990 09-17-13, 08:51 AM
