09-17-14, 07:43 PM
Being that Im waiting for my new driveshaft to come.
I went back and re checked my timing. From preavious posts I had on engine shutter. I found out that I was wrongly adjusting the vacuum advance in the wrong direction.
I thought I had this put to bed. But NO...
So just for fun. I threw as much initial timing at it without it causing it to roll back on the starter. I ended up at 19 degrees of initial timing and the car idled the best it ever idled. The throttle was crisp and the engine came alive!
The vacuum came up to a steady 19 inches from the usual 15 to 16 inches of vacuum.
I love it!
I did a 2000 rpm pull to see where I was at "ALL IN" without vacuum advance.
It was off the chart.
Id guess Im at 46 to 50 degrees.. I even got it to knock when I pushed it to 2500 rpm.
So I now need to figure out if my distributor is adjustable? Its either a MP distributor or a mother mopar unit. Its electronic. No points and it accepts mopar cap and rotor.
Ive read that you can limit total advance with shims and then it lock down?
Its got the PINK springs.
My head is spining and now I wonder if my balancer has "walked"...
Ill check my balancer marks via spark plug hole tomarrow.
Has anyone been down this road?
Thanks again!
383/727
Cam unknown.
Timing chain New!
Compression test not yet done.
Edlebrock 1406
I love it!
Thanks again!
383/727
Cam unknown.
Timing chain New!
Edlebrock 1406
