Auto Transmission selector shaft seal remover and intstaller
http://atec-trans-tool.com/search.aspx?find=t-1031-A
This handy tool is a huge time saver in replacing the National #8609 seal with out removing valve body
seal is a National #8609
The little center seal comes in a tansmission kit but stop buy a trans. shop they usually have a couple laying around in there tool box
I have replaced at least 10 of those seals in my life and removed the valve body every time. that would be a great tool to have, but at that price(I`m poor) I`ll keep removing the valve body.
The 8609 seal which is the bigger one that goes in the housing is old part number 2466-842 and the new Mopar number is 1-04505098.
The smaller seal that goes in between the two levers is old part number 2466-548 and right now I can't find the new number.
You can always just get the parts guy to look up a 98 or so Dodge pickup with a Cummins and auto and they will be the same.
  some drive shaft #s and lengths 67r/t4speeder 0 14,655 07-13-15, 12:29 PM
