1959-1974 Power Window Switch Part Numbers Guide
Below are all of the part numbers for Plymouth, Dodge, DeSoto, Chrysler and Imperial electric window lift switches listed in model year order.
1959 Model Year:
Part number: 1770 503 (use 3 per car)
Factory parts book section number: 23-41-170
Part description: switch, electric window lift, single gang, includes bezel
Application: all Plymouth models equipped with factory electric windows
Application: all Dodge models equipped with factory electric windows
Application: all DeSoto models equipped with factory electric windows
Application: all Chrysler models equipped with factory electric windows
Application: all Imperial models equipped with factory electric windows
Part number: 1770 509 (use 3 per car)
Part description: switch, electric window lift, single gang, less bezel
Part number: 1770 507 (use 1 per car)
Part description: switch, electric window lift, four gang, includes bezel
Part number: 1770 513 (use 1 per car)
Part description: switch, electric window lift, four gang, less bezel
Purge Spammer
1960 Model Year:
Part number: 2096 399 (use 3 per car)
Part number: 2096 765 (use 3 per car)
Application: All Imperial models equipped with factory electric windows
Part number: 2096 177 (use 1 per car)
Part description: switch, electric window lift and vent wing, two gang, includes bezel
Application: all Imperial models equipped with factory electric windows and electric vent wing windows
Part number: 2096 089 (use 1 per car)
Part number: 2096 090 (use 1 per car)
Part number: 2096 176 (use 1 per car)
Part description: switch, electric window lift and vent wing, six gang, includes bezel
Purge Spammer
1961 Model Year:
Part number: not available at this time
Application: not available at this time
Purge Spammer
1962 Model Year:
Purge Spammer
1963 Model Year:
Application: all Dodge models except Dart equipped with factory electric windows
Application: all Plymouth models except Valiant equipped with factory electric windows
Application: some Chrysler models equipped with factory electric windows
Part number: 2427 144 (use 1 per car)
Part description: switch, electric window lift, single gang, rear, right side, includes bezel
Application: some Chrysler luxury models equipped with factory electric windows
Part number: 2427 814 (use 1 per car)
Part description: switch, electric window lift, single gang, rear, left side, includes bezel
Purge Spammer
1964 Model Year:
Part number: 2427 184 (use as needed)
Application: some Imperial models equipped with factory electric windows
Part number: 2427 213 (use as needed)
Part description: switch, electric window lift, double gang
Part number: 2427 184 (use 1 per car)
Part description: switch, electric vent wing, single gang, right side
Application: all Imperial models equipped with factory electric vent wing windows
Part number: 2427 213 (use 1 per car)
Part description: switch, electric vent wing, double gang, left side
Purge Spammer
1965 Model Year:
Application: all Plymouth Belvedere models equipped with factory electric windows
Application: all Dodge Coronet models equipped with factory electric windows
Part number: 2580 614 (use 3 per car)
Part number: 2427 184 (use 3 per car)
Part number: 2497 583 (use 1 per car)
Part description: switch, front door power vent, single gang, right side
Application: some Plymouth C-Body models equipped with front door power vent windows
Application: some Dodge C-Body models equipped with front door power vent windows
Application: some Chrysler models equipped with front door power vent windows
Application: some Imperial models equipped with front door power vent windows
Part number: 2427 213 (use 2 per car)
Part description: switch, electric window lift, dual gang, left side, includes bezel
Part number: 2497 584 (use 1 per car)
Part description: switch, front door power vent, dual gang, left side
Part description: switch, electric window lift, four gang, front door, left side, includes bezel
Part number:2580 613 (use 1 per car)
Application: all Plymouth C-Body models equipped with factory electric windows
Application: all Dodge C-Body models equipped with factory electric windows
Purge Spammer
1966 Model Year:
Application: all Plymouth Satellite models equipped with factory electric windows
Application: all Dodge Charger models equipped with factory electric windows
Application" all Chrysler models equipped with factory electric windows
Application: all Plymouth C-Body models equipped with front door power vent windows
Application: all Dodge C-Body models equipped with front door power vent windows
Application: all Chrysler models equipped with front door power vent windows
Application: all Imperial models equipped with front door power vent windows
Part description: switch, electric window lift, dual gang, includes bezel
Part number: 2580 613 (use 1 per car)
Purge Spammer
1967 Model Year:
Part number: 2770 166 (use 1 per car)
Part description: switch, right front door window lift, without power door locks, without power vent windows
Application: all Imperial models with factory electric windows, without power door locks, without power vent windows
Part number: 2770 164 (use 1 per car)
Part description: switch, right front door window lift, with power door locks, without power vent windows
Application: all Imperial models equipped with factory electric windows, with power door locks, without power vent windows
Part number: 2770 162 (use 1 per car)
Part description: switch, right front door window lift, without power door locks, with power vent windows
Application: all Imperial models equipped with factory electric windows, without power door locks, with power vent windows
Part number: 2770 160 (use 1 per car)
Part description: switch, right front door window lift, with power door locks, with power vent windows
Application: all Imperial models equipped with factory electric windows, with power door locks, with power vent windows
Part number: 2770 167 (use 1 per car)
Part description: switch, left front door window lift, without power door locks, without power vent windows
Application: all Imperial models equipped with factory electric windows, without power door locks, without power vent windows
Part number: 2770 163 (use 1 per car)
Part description: switch, left front door window lift, without power door locks, with power vent windows
Part number: 2770 165 (use 1 per car)
Part description: switch, left front door window lift, with power door locks, without power vent windows
Part number: 2770 161 (use 1 per car)
Part description: switch, left front door window lift, with power door locks, with power vent windows
Part number: 2770 174 (use 4 per car)
Part description: switch, rear door and quarter window lift, single gang
Part description: switch, single gang, right side front door, rear door, quarter window, window lift
Part description: switch, single gang, right side, front door power vent
Application: all Chrysler models equipped with power vent windows
Part description: switch, dual gang, left side, front door power vent
Part description: switch, four gang, left front door window lift
Purge Spammer
1968 Model Year:
Part description: switch, electric window lift, single gang, right side front door, rear door, quarter window, includes bezel
Part description: switch, single gang, right side, front door power vent wing window
Application: all Chrysler models equipped with front door power vent wing windows
Part number: 2857 847 (use 4 per car)
Part description: switch, dual gang, left side, front door power vent wing window
Part number: 2857 848 (use 1 per car)
Part number: 2857 850 (use 1 per car)
Part number: 2857 852 (use 1 per car)
Part number: 2857 854 (use 1 per car)
Part number: 2857 849 (use 1 per car)
Part number: 2857 851 (use 1 per car)
Part number: 2857 853 (use 1 per car)
Part number: 2857 855 (use 1 per car)
Purge Spammer
  Interior Trim Information Guide thebankerstoy 3 10,267 04-24-22, 10:58 PM
Last Post: Piper
  1966-1970 Coronet Electric Window Wiring Diagrams thebankerstoy 9 59,085 07-30-14, 11:12 PM
  1966 & 1967 Coronet & Charger Back-up Lamp Interchange Guide thebankerstoy 2 8,767 04-30-14, 05:44 PM
  1966 & 1967 B-Body Lower Instrument Panel moulding Trim Guide thebankerstoy 7 13,361 04-26-14, 12:47 PM
  1966 & 1967 B-Body Window Glass & Weatherstrip Interchange Guide thebankerstoy 11 22,370 04-21-14, 05:31 PM
