07-07-14, 11:58 AM
This could be the end to my summer cruise season.
Long story short...
I bought a set of Magnum wheels through Craigslist late last year and had them installed. As it turned out, these were from a Ford and they were rubbing on my upper control arm (in the front... the rear wheels are fine).
After I realized this... I did some research and decided to use spacers to get these to fit.
This past week, I learned that I had managed to shear off 3 of the 5 studs on the drivers side... I haven't checked the passenger side, those may be damaged as well.
This also caused a really weird/bad wear pattern on the driver side front tire... so I may need a new tire as well.
I'm am looking at either getting 2 new Magnum 500's for the front or just getting 4 all new wheels and tires.
I want to be sure about the correct backspacing for a 1966 Dodge Coronet... I have seen a couple other threads and it seems like 4.25 in. Backspace is correct.
So, if I am looking at a new set of wheels, I should be looking at 4.25 backspacing???
Anybody have any leads on a new set on MOPAR Magnum 500's??
Here's a shot of my sheared studs... will I be able to get this off and take it somewhere to get the replaced and is this a good time to ditch the "reverse threaded" studs??
4393
I just asked a lot of questions and I usually do ask a lot of questions here, but you guys always help me.
THANKS in advance!
-Dan
Long story short...
4393
THANKS in advance!
-Dan
![[Image: Ricks1972DartSwinger-RichardTruesdellpho...0846-1.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/Ricks%201972%20Dart%20Swinger/Ricks1972DartSwinger-RichardTruesdellphoto-Jan200846-1.jpg)
![[Image: 1972DartSwinger-14x6Magnum500wheelsP225-...Atires.jpg]](http://i146.photobucket.com/albums/r248/thebankerstoy/Ricks%201972%20Dart%20Swinger/1972DartSwinger-14x6Magnum500wheelsP225-70R-14BFGRadialTAtires.jpg)
