Vin Number and Fender Tag help, with history of my car...
I have checked several websites, tried to decode it myself, and its always conflicting what I am suppose to have and not have.
Thought I would give it a go here, this site seems to be really knowledgeable in Coronets specific.
My vin# is WP23D71147743
Here is pic of my fender tag also...
Any help you guys could give would be great.
67 Coronet 500 "old yeller"
[SIGPIC][/SIGPIC]
All I know is it has 58k orig miles(supposedly) older couple had bought it new in Kingsport TN. I am third owner I believe...so most if anything done to car was done from the original owner.
car has 273 with a 4bbl(looks factory) bucket seats console, air condition automatic car.
Yellow with black interior. I can tell interior was once white, and one of the websites said it had a white vinyl top on it...??? dunno. then one website says nothing about it.
hope you all can shed some light on it.
[SIGPIC][/SIGPIC]
awesome...low production number for the combo then... cool.
what is easiest way to find out what size rear housing I have?
diameter of rear axel sleeves? hog head? etc...
[SIGPIC][/SIGPIC]
[Image: Mopar_axle.jpg]
nice 8 3/4
[SIGPIC][/SIGPIC]
5 - Torqueflite Automatic Transmission
How can one tell which torqueflight they have, wasn't there 2 of them?
There were 3 automatics. 1-small block 318's used the A904LA type. 2-big blocks used the A727B. 3-small blocks with high performance applications (like the 340) used the 727A. Auto trans type can be id'd by the family code that appears in raised letters that are 3/8 inch high on the lower left hand side of the bell housing. This is only the family type and there are internal differences within each family. On the oil pan side rail on the drivers side of the trans is a serial number which can further id build date, assembly plant, and the trans part number.
easiest way to ID a trans in the car- 904 pan is in the shape of a square with a corner cut off. a 727 will be square with an extra piece on one corner. 904 only came behind small blocks. 727 came behind small and big blocks but are not interchangeable(only internally)
nice info
[SIGPIC][/SIGPIC]
The VIN breaks down as follows:
W = Coronet
P = Premium
23 = 2Dr Hardtop
D = 273-2 V8
7 = 1967
1 = Lynch Road Plant
147743 = Sequence Number
Also ax = 5 is the 2.94:1 ratio.
The certicard will have additional info on it about the trans and axle.
  WS27U0G100411 Looking for history on this '70 RT Convert RHORNE14 0 11,261 12-16-20, 03:16 PM
Last Post: RHORNE14
  Looking for history: 1968 Coronet R/T VIN: WS23L8E150142 Jace 0 13,707 01-15-16, 12:03 AM
Last Post: Jace
  Looking for history on my 68 RT Dodgedude 0 4,188 08-21-15, 10:51 AM
Last Post: Dodgedude
  Car History...WH23F9G153192 markbob@ameritech.net 1 5,305 02-28-15, 12:16 AM
Last Post: moparforlife
  66 Coronet Fender Tag LewM 2 5,073 07-22-14, 12:28 AM
  66 Coronet Fender Tag thunderchicken 18 12,505 05-29-14, 04:28 PM
Last Post: thunderchicken
  Just a fender tag i found..69 4 speed 69rag500 16 12,466 05-12-14, 01:00 AM
  Canadian export 1970 Coronet R/T convertible - history? mozz at rpm 3 5,322 03-21-14, 12:41 PM
  Anyone know the history of my car? kurtsdodge 4 6,497 10-08-13, 08:33 PM
Last Post: kurtsdodge
