Penetrating oils info
For all you gear heads:
Some of you may know this already, but this the testing data behind why it works so well.
[INDENT]
[TABLE]
[TR]
[TD="width: 100%"][SIZE=2]
"Machinist's Workshop" recently published information on various
penetrating oils. The magazine reports they tested these products for
"break out "torque" on rusted nuts and bolts. A subjective test was made
of popular penetrating oils, with the unit of merit being the torque
required to remove the nut from a "scientifically rusted" bolt. Average
torque load to loosen nut:
No Oil used ........................516 foot pounds
WD-40 ..................... ........238 foot pounds
PB Blaster .........................214 foot pounds
Liquid Wrench ......................127 foot pounds
Kano Kroil .........................106 foot pounds
ATF/Acetone mix...................... 53 foot pounds
The ATF/Acetone mix is a "home brew" mix of 50/50 automatic transmission
fluid and acetone. Note this "home brew" released bolts better than any
commercial product in this one particular test.
Our local machinist group mixed up a batch, and we all now use it with
equally good results. Note also that Liquid Wrench is almost as good as
Kroil for 20% of the price. ATF/Acetone mix is best, but you can also
use ATF and lacquer thinner in a 50/50 mix. ATF = Any type of Automatic
Transmission Fluid.
[Image: Under%20Contstruction%20smiley%20face%20clipart.jpg]
[/TD]
[/TR]
[/TABLE]
[/SIZE]
[/INDENT]
Excellent information! Thanks for posting it.
Thanks Andy, always knew WS-40 was useless. Funny though I've always use PB blaster and Liquid Wrench equally.
They are convenient in an aerosol can.
ws27 Wrote:Thanks Andy, always knew WS-40 was useless. Funny though I've always use PB blaster and Liquid Wrench equally.
WD-40 is excellent for drying (old) wet ignition wires.... and it also works really well to remove road tar. But really not much more.
My favorite penetrating fluid is SeaFoam Deep Creep. I have used a lot of products at our shop over the years and this was the best; plus it is safe to use around plastics, paints, and protective coatings! The best part is that it does not flame up when you use torches... which is a necessity in our area of Canada.
FYI: For those of you who are into guns... this is the product for you, trust me.
PS: I do not sell this stuff, I just really like it.
http://seafoamsales.com/deep-creep/why-d...eep-works/
FRATZOG Wrote:WD-40 is excellent for drying (old) wet ignition wires.... and it also works really well to remove road tar. But really not much more.
I've used it before too, works pretty good..
I'm into guns. Where can this deep-creep be purchased in Canada?
4264door Wrote:I'm into guns. Where can this deep-creep be purchased in Canada?
Any Napa store, Best Buy Auto Parts, some Canadian Tire Stores too. Check here:
http://seafoamsales.com/canadian-retailers/
I'll go check out my local CT store today, thanks for the info!
Great info., Thanks!!!
