Threads: 8
I am adding this to the car along with an MSD 6al box and blaster coil. The one I have has no vacuum advance. Installation instruction diagram shows to use the white wire from the box to the red wire from the distributor. Is this correct. In all of the msd that I have installed, I have never used the white wire. A Little input please.
Thanks
Jay Nordstrom
Threads: 474
That's a nice one being built in rev limiter, not sure if I have installed one with box also though
there tech line is good.
Threads: 308
On a MSD 6, the white wire isn't normally used, it can be used as a way to kill the ignition. It looks on the 6AL and 6AL2, it's used as the distributor input.
I'd connect it up the way the manual says.
Threads: 474
How did it go Jay ?
