i finally got some paint shot yesterday
I got the fire wall, inner fenders, bottom side of the hood, door jams, and inside the trunk painted. now I have to put it back together and paint the rest. I mixed 2 gal. of flat black w/ 1/2 gal gloss black rustoleum.
2943
Did you do the body work? It looks really nice.
thanks! yes i did the body work and all the other work.
VERY nice work you've done indeed! I'm really looking forward to seeing more pictures as you go along with this extremely cool project!
Wow, looking great. will it be ready for Carlilse 2014?
ws27 Wrote:Wow, looking great. will it be ready for Carlilse 2014?
maybe 2015, the car is an empty shell right now. everything major was fit on and then removed for painting. i do need to make door panels and put the entire interior back in w/dakota buckets/stock rear seat(that still needs recovering), new dolphin gauges. all the glass is out too. it also sits about 4" to high in the front and rear so i need to buy and put in drop spindles/lowering coil springs(has 88 dakota front clip). and i`m going to swap out the original leaf springs for a set of 80's truck springs, they have almost the same front and rear sections with out as much arch. but i need to put in different spring mounts/shackles as the 1947 springs are about 1.75" wide. i also have to make a wireing harness from a dakota work with everything on the car it has a dakota steering column in it. also need to bend/flare all the brake/fuel/hyd. clutch lines. cut/weld/fit/piece together a full length dual exhaust system from the universal dual exhaust kit i bought. AND pretty much everything else. but the body work/cutting/welding/taking the front end off/on 200 times (the hard part) is done!
got the front end on, motor/trans. and new radiator in and painted it today. it still glossy because its wet. it will be semigloss when it dries.
[Image: desotopaint006_zps496f0852.jpg]
WOW that is looking so nice. Good choice on the semi gloss.
Stock chrome going back on?
all the chrome trim was not with the car when I got it and some of it was damaged. rather than go through the expense of replacing/repairing it I just welded all the holes closed and smoothed them out. the only trim that's going back on it the chrome that connects to the grill and goes back above the front wheel. also the hood ornament is going back on because its sooooo cool!
a before pic(7 years ago)-
[Image: dcaa6a7c.jpg]
WOW that is just such a VERY cool looking car indeed!!! What wheels and tires are you going to run?
  66 Coronet 2 door sedan paint codes Hemi 528 0 1,099 12-30-21, 10:41 PM
Last Post: Hemi 528
  Bring paint back (even if temporary) Piper 28 26,296 07-16-19, 05:50 PM
  Pulled motor and trans yesterday ... 67RTBlue 3 2,955 06-25-18, 10:49 PM
  Finally i'm going on Vacation! Warhawkfight34 4 3,593 12-12-15, 01:08 AM
  Maiden voyage of my CORONET FINALLY!!!!!! Warhawkfight34 15 8,633 07-26-14, 06:17 AM
Last Post: TekHousE
  Finally got to go out with Annette this weekend! Warhawkfight34 1 2,546 07-21-14, 01:35 PM
Last Post: 4264door
  Finally got to go out with Annette this weekend! Warhawkfight34 1 2,776 07-21-14, 10:58 AM
  Engine is FINALLY INSTALLED Warhawkfight34 10 6,213 06-12-14, 08:29 PM
Last Post: dadstoy65
  Touch up paint Avenger 2 3,137 05-22-13, 06:04 PM
Last Post: Avenger
  Guess what I found yesterday! Ledsled 75 20 7,765 05-11-13, 12:42 AM
