Threads: 3
The instructions for a Centerforce diaphragm type clutch state that you should not use a clutch pedal return spring with this type of clutch. Which spring are they talking about?
1. The large over-center spring inside the car or...
2. The smaller spring that runs from the bell housing to the fork.
The large over center one inside.
Threads: 13
If you don't remove the over center spring, the clutch pedal will stick to the floor at higher RPM's. I found out first hand!
Threads: 8
It's not all that easy to remove IIRC.
Threads: 3
Thanks guys. I thought that the heavy one inside is what they meant, but I just wanted to be sure.
Threads: 40
4264door Wrote:It's not all that easy to remove IIRC.
Not too hard - depress the pedal and put shims between the coils and it will slip right off.
Threads: 482
Mark has some great tips, thankyou Mark
